1000W Simple PA Amplifier
Hello. I build ba1200 width 4 output pair, supply 40V DC. Without input signal i got on output 2,3v DC
What is wrong ? Any suggest ?
What i did:
- removed damaged amplifier section oryginal magnat 480
- mounted ba1000
- rewinded trafo up to +/- 40v at 14,4v 2x1x1.5
What i will do:
- sample output tranzistors to MJL in ba1000
- add subwoofer filters 20hz hpf and virable 30-100 lpf
- use amplifier protection circuit build in power supply
- add amplifier mute synchronizetd width power supply
- rewind trafo up to +/- 70v at 14,4v
What i did:
- mounted ba1000
What i will do:
Nice work.
Assess the SOA capability of the output stage by using the relationship:
Maximum Output power is ~ Total output device power rating divided by 4.
This applies to normal ClassAB amplifiers.
The switched rail type are quite different.
I don't have a rule for them.
eg.
for classAB
using a 4pair output stage of 250W devices equates to total device power rating of 2000W.
Maximum power is ~ 500W.
mjl4281 is 230W
9pair is 4140W
At very high supply voltage I would aim for divide by 5. If they are to run hot as well then divide by 6.
But switched rail amplifiers do it differently.
That divide by 4, or 5, or 6 does not apply.
different duty requires different device parameters.
D3 & D4 should be small signal diodes, try 1n4148.
D2, D5 & D6 may be OK to leave as power diodes, 1n4002 or above.
D7 & D8 must be power diodes.
But the back emf and the resulting current coming from the speaker and it's crossover components cannot be that high, that 1n540x devices must be used.
I use 1n4003 or above here. But I don't drive 1kW speakers. Maybe the peak transient currents from really big speakers can exceed the short term peak capabilities of the 1n400x series.
ok, great, thanks
I might have a combination use for this amp
as bass guitar amp driving 18" woofer
and as a mono sub amp with EQ, driving the same woofer for hifi music
and it might do both at the same time, when I figure out how 😛
