10" subwoofer enclosure is too big
Hey all, I'm new here 🙂
I've used winisd to design my first subwoofer using dayton 10" RSS265HF-4.
I tried to tune my vented speaker to 22Hz and I got a ridiculously big sub in size 30x60x60cm to make it to the required volume of 0.08m^3.
Can anyone tell what I did wrong? I saw speakers much smaller than this at 35x35x35 in size.
.45 qts
1.9ft3 vas
25.6hz fs
I read a while back, a jbl had f3 of 45hz in .707 sealed.
It measured flat to 8hz in a 100ft3 vehicle.
You have met hoffmans iron law.
Size - efficiency - low notes
You can get low f3 but it takes a bigger box.
I find a 15" needs 4-8ft3 for a standard ported box to have f3 just below 30hz.
Greets!
This is a good size for sealed.
For vented, a Vb = [published] Vas/1.44 = 37.51 L tuned to 25.6 Hz [Fs] is 56 L net including a very large vent [140.32 cm^2 x 132 cm long] to handle its 350 W power rating down to Fs, so could be smaller if the power required is lower.
GM
The Qts is more suited for a closed cabinet with 37L Q=.707 40Hz
You can reach the same 40Hz with a tiny 14L enclosure when using a series capacitor of 900uF.
the efficiency is very low, with a 700W amp it will only reach 105dB free standing.
Depends on whether the sub is in a room null or peak or where it's between them, so the norm is to either use sealed or low tune a vented sub to give it a similar initial roll off slope as a compromise and use some form of EQ to finish blending it to the room.
In short, unless tone deaf, no.
GM
Try bringing your F3 up a little tuning the port down to 22Hz is a bit low for that 10" and 80lt vented is to big, they seem to recommend around an F3 of 27Hz .
Im finding 50lt ported at 30Hz will give a F3 around 27hz while keeping port length practical and velocity reasonably low(2 of 86.5x718mm, its locally to me available pvc pipe).
Im using Winisd.
You will need a subsonic filter if using for HT use
