10 band EQ all tubes
Yes, there's also a Compactron triple triode that actually is three halves of a 12AX7. I've seen it in some Fender amplifiers of the 1980ies. Sadly I don't remember it's designator and I also don't know if it is cheap enough 😱.
Best regards!
Thanks, Osvaldo, this is the tube!
Have I told you yet that I'm not that familiar with compactrons, as they aren't exactly familiar in Europe? I regard that as a pity, as they apparently are really interesting tubes. Oh, and they look sexy, too 😛.
Best regards!
They went another way: Keeping B9A/Noval for small signal and low power tubes, swapping for Magnoval for higher power ones when International Octal went out of fashion.
Big tubes like PL519/40KG6A per manufacturers' advice need to be prevented from falling off their sockets. I guess this wasn't necessary for Compactrons due to three additional pins and a superior diameter to height ratio?
As said several times: It's dissappointing, at least for me, that Compactrons never were common here, hence aren't that easily to acquire, for not to speak on one Euro lists 🙁.
Best regards!
Although the outline characteristics are different, the real advantage is inside the glass. There are some uncommonly high pentode, like the one designed for TF video IF with 30mS of transconductance, triple of the EF183/4 pair. Don't being remembering now the part name.
In Europe there were for video amplifier services the tubes PFL200 (21 mS), PCL200 (28 mS) and PL802 (40 mS) as the final developments. Televisions with them usually had pictures with more contrast than those with their predecessors (PCL84, PL83). Especially PCL200 is an interesting tube, as it's triode exactly is half a 12AT7. PL802 has become scarce and expensive for some time, but seems to be available again nowadays for decent money.
Best regards!
The Blonder-Tongue Audio Baton replica on the way, I just finished one channel and test it.
I stick to the original schematic but I add a 5 led bar graph, led VU meter and an unusual power supply that works very well.
The second channel will be upside down for fit inside a 3U cabinet and when finish will looks as the picture of the front panel. Both channel will be completely independent.
Sound is excellent just some minor noise issue but I will work out on it, this is just the first test.
All the best to everybody.
