Simple Oscilloscope Question
Hi.
I need to buy an inexpensive oscilloscope to measure the output signal/voltage from my turntable cartridge from each channel so I can set Azimuth and be sure that the left and right channel are outputting the same level.
I know nothing about these things but I see prices betwen 40 bucks to thousands. Can I get away with a cheap one for this purpose?
https://www.amazon.com/HANMATEK-HO1...-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Thanks,
Stu
No, you first just verify that the phono preamp gains are matched between channels, and then use it normally and measure the outputs. Measuring a few mV directly from the cartridge is not trivial. The phono stage outputs will be 50x to 100x larger at 1kHz
than the inputs.
A scope without good bandwidth limiting simply isn't suitable, 100MHz of noise is 100 times the amplitude of 10kHz worth of noise, all else being equal.
Checking azimuth requires a test disc with separate left and right channel tracks, tune for minimum crosstalk, don't expect better than -40dB crosstalk from vinyl, but the ear doesn't really care below -30dB anyway.
Measure after the phono preamp or you might be injecting more signal than you measure!
Equalizing the output levels involves having some gain/balance adjusting circuit - the balance control on an integrated amp for instance.
Azimuth is about keeping left and right separate, not matching levels.
