Choctaw - 10 Watt Amplifier, 1 Opamp + 2 MOSFET
Still not working, pin 2 and 3 were also reversed.
Changed this in schematic and ordered new PCB's.
Who got this amp (10W Lineup's design) up and playing?
My build is based on Zoltan's stereo PCB (thank you Zoltan).
What is recommended heatsink size/model?
For my first test I have used 150mm x 150mm x 3mm steel panel (5" x 5" x 1/8") and IMO it's too hot after 5 minutes.
PS at main capacitors is +/- 16V.
BTW, I like the sound.
Reactions: ZoltanChivay
Benpe
I'm glad everything is OK and that you didn't have any problems with starting
I mentioned that we need a large heat sink
We have about 400mA of quiescent current
With a power supply of about +/- 16V for two channels we have 26W of heat to dissipate.....
Mine is 170 x 40 x 80mm It's warm but not hot
Here is the new Choctaw circuit. It is the 19th version I have in my computer!
New is the compensation cap 22pF to the opamp out.
I added also a cap across the feedback resistor 47pF.
This 47pF is to see as a lowpass filter. Reduces -3dB bandwidth to 200kHz.
Distortion simulated is THD 0.00093%
PhaseMargin is 76 Deg.
I hope this will be the Final circuit.
Oh, missing are the decoupling caps around the opamps supply rails. Two 100nF caps
here is my "spin" on the amplifier i did forget a few parts but the most important thing is running it in relatively high bias class AB the 7.48KΩ resistor is an 680 ohm and an 6.8kΩ represented as a single resistor, if such a thing as an dual trimmer potentiometer actually exists id be happy use it here as an replacement for the resistors so you can adjust the bias more precisely.
As shown, I agree with the previous posts; it will likely self-destruct. Adding a vibe multiplier and transistor on the heatsink will help stabilize the circuit, but you may need to consider how the asymmetrical feed of the opamp to the output transistors will affect the output voltage swing. Vertical mosfets usually have a higher threshold voltage than laterals, which may also affect things. Another concern is the high impedance path from the opamp output to the transistor gates.
Good luck with it.
