Best DIY CLASS AB
Hi all
As DIY forum has been resourceful to many enthusiastics around the world i would like to take experiences to a single thread. So in the future if anybody visit the forum could get a idea about different designs. I'm also one of them, a novice.
Please share your class AB experiences of DIY forum introduced builds. There adding measurement results SQ etc. if you have would be a good help for the research.
If you have done any personal modifications please tell that also.
Hi all
Except the single ended power amp approaches all output buffers in power amps (mostly in power follower configuration) of exist analog solid state amps for audio application actually runs in Class AB. In colloquial English, however, all power amplifiers with push-pull outputs are always advertised as Class-A if the quiescent current in the output stage is around 350-400mA or above (like e. g. Musical Fidelity A1)
Thus for me there are three different Class AB variants regarding the push pull true- or quasi-complementary output stages:
1) with 20-50mA quiescent current and BjT power devices (typical Class AB)
2) with 100-150mA quiescent current and power MOSFET's
3) with more than 350-400mA quiescent current (quasi-Class-A).
I assume that the variants of 1) and 2) are meant here. Here are my favorites regarded this:
NDFL
https://www.diyaudio.com/community/attachments/ndfl-pdf.385251/
https://www.diyaudio.com/community/threads/new-cherry-ndfl-amp.148066/
Renardson's MjR amplifiers
https://linearaudio.net/sites/linearaudio.net/files/renardson new class B.pdf
https://www.renardson-audio.com
https://www.diyaudio.com/community/threads/mjr7-mk5-by-renardson.301356/
But there are other interesting approaches to provide higher efficiency as possible in Class-A (but more difficult to reach excellent results).
I know this:
Current Dumping (like Quad 405, consist of a Class-A single ended small power output stage + Class B large power stage)
https://www.diyaudio.com/community/threads/quad-405-revisited-tl071-vertical-mosfets.163929/
https://www.diyaudio.com/community/threads/current-dumping-revisited.343136/
https://www.diyaudio.com/community/threads/quad-405-revisited-ad844-vertical-mosfets.163638/#:~:text=The QUAD 405 structure enables,Class AB amplifier can provide.
https://www.diyaudio.com/community/...ss-a-performance-with-no-idle-current.376644/
Yamaha's HCA (even here exist two output stages for the whole power amplifier: hard running output stage with very small supply voltage and a usual Class AB stage)
https://www.diyaudio.com/community/threads/yamaha-hca-circuit.128392/
https://www.diyaudio.com/community/...-conversion-amplification-hca-circuit.152734/
https://www.diyaudio.com/community/threads/a-yamaha-hyperbolic-conversion-hca-clone-the-hhca.353441/
But my absolutely favorite are power amplifiers with a Circlotron (PPP) output buffer stage (two power supplies for each Channel necessary) and of course the single ended versions like Pass First Watt and Aleph series.
I know this:
I would add circuits that use Schottky diodes for a non-switchable output stage. This reduces distortion and provides some benefits.
https://www.diyaudio.com/community/threads/new-class-a-super-a-non-switching-need-a-revival.162559
https://www.diyaudio.com/community/threads/very-simple-mosfet-design-in-class-a-a-b.404961
NDFL
I know this:
That’s great info and thanks a lot for that. I was also looking for this info rather than finding the best. only later I realized title is mistaken.
if possible please show your builds if not much hassle.
