SAE A205 amp, mosFET?
I was offered a Sae A205 amp, there is not much info out there, plenty of power, looks like a Acurus or Adcom mosfet amp.
but I am not sure.
Is this a Mosfet amp ?
what are the bias number without a service manual ?
Is the design any good ?
100wpc Class A/200wpc Class AB1.
4x Toshiba 2SA1302, 4 x 2SC3281 each side
thanks for your help
Yet another "leach" amp ( fully complimentary).
Strengths =
- Very good PSRR , they cancel supply ripple natively.
-simple and easy to understand with simple compensation - very stable.
Weaknesses = 3rd and 5th distortion products and will always require offset adjust
and-or P/N matching.
Below is the simple version of this topology , used in most A/B subwoofer plate amps (80% of them). Still .01% THD.
Dayton plate amps are this circuit.
Good deal , the case and the amp for 75$ ... I'd buy it. Trafo alone goes for 100$+
Bias , first test one of the emitter resistors (big grey ones). 20mV would give you @40mA per device.
I don't see any trimmers for either offset or bias on any google picture of this amp.
What were they thinking ??
Board layout looks different from either schematic.
Zener biased LTP's , no ripple eaters , no adjustment trimmers offset by top quality silver mica caps and a beefy
power supply ???? strange.
OS
Looking closely at the pictures , 8 trannies in the middle are the LTP's and cascodes (+/-). can see the 2 current sources (2 trannies all alone at the top).
No large driver transistors ... it might be the circuit I posted driving LATFET outputs.
