EZ81 x 2 in parallel
They did that in the Philips BX732A with EZ80s. These rectifiers are high impedance. They will equalize their current load even when they age to some extent. But why not use a single GZ34 if you insist on using vacuum tech?
GZ34 will only do 250mA and I need at least 300mA. I would like 500mA so a pair of GZ35 seems like a viable option. So do I just common the cathodes and feed the plates via individual resistors? Can I double the value of the reservoir capacitor?
Cheers
Ian
You can rectify with silicon and then before getting to the first capacitor you use a (TV) damper diode. Only one is required and it creates a slow startup plus it gets rid of the cr@p introduced by silicon diodes. Use a small capacitor, then a choke and after that a capacitor as big as you like, in my case it is two 64u in series (giving 34u), a 5H choke, then 150u and then a resistor followed by 150u. You can even go further and use two resistors followed by a capacitor each to go to each channel.
Due to a purchased PCB I am using the damper diode in line with the transformer c.t. connection (with a fuse) rather than cutting tracks on the PCB.
Is there a table anywhere listing rectifier valves?
