Rockford Fosgate T30001bd
Hey Perry I got another one T30001bd amp in. I rebuilt the powersupply and the audio board. When HV is not connected and only the ribbon cables are, I get a drive signal only on 2 of the 4 banks. Checking the signal on pin 7 of u301 and u302 they are both almost undetected or distorted. I placed a 1k ohm resistor across pin 1 & 2 of u301 and got a clean square wave. No I have drive signal on all 4 banks. I also had the correct waveforms on u400 and u401. I did power the amp the banks did not share the voltage on outputs.
The voltage, positive and negative may not be perfectly equal.
The inductor could be shorted. Try twisting it while the amp is trying to go into protect. I'd use a limiter so the outputs aren't getting stressed if the problem is over-current related. Having broken legs on the filter caps can also cause the amp to go into protect.
When you tested with no rail voltage, did you have a 50% duty cycle drive signal?
I replaced the switches and gain pot since these are known issues. I removed the 1k resistor off the feedback loop and lost m all the drive signals. I started tapping on the circuit board around rcas and got the drives back. Going to reflow the ops pa conncections.
Drive signal no feedback resistor in place
