there is a difference between the N and P types.
not so easy to fab.
1+1+4 year patent license is up pham.
sing ya later! ( .68 B euros later to the bank ;] )
not so easy to fab.
heard those supposedly linear transfer jfets are referred to as 'blobs' in the industry. guess the process yields what looks like 'blobs' on die, thus the moniker.
not so easy to fab.
There is no such thing as an enhancement mode JFET. There is no way to create a built in field to adjust the threshold like a MOSFET.
EDIT - It must be happy hour.
of course not.
because you said so.
YouTube
...........the process yields what looks like 'blobs' on die,............
"Blob" may imply they are hiding something. A teeny battery?
It seems to be happy WEEK. Cheers!
How would you call a Semelab SML100M12MSF then?
SML100M12MSF Semelab / TT Electronics | Mouser Europe
Sorry physics says so.
True for the standard JFET device.
Not true for non standard and a hardly integrable layout and process:
US7180105B2 - Normally off JFET
- Google Patents
Much easier to do on wide bandgap materials like SiC, since they allow forward biasing the JFET gate without much leakage. A heroic effort is required for a normally off silicon JFET, see the above Infineon patent. The “pinch” voltage in this case is limited to some 0.2-0.4V before the exponential gate current kicks in and makes a mess of the conduction mechanism. Under the circumstances, I would think a high channel conductance would require a huge silicon area.
thanks for the advice on transistors way back
what is this physics you speak of??
here's the small signal
revisited
now how in the world could two devices be placed on the same epitaxial layer?
just put them on the die precisely, like an older chipset for a XEON perhaps
pennies on the dollar for the full process lolol
- Design & Build
- Parts
- Enhancement mode JFET
