Analog VU meter in power amplifier
I have the big VU meter panel from a scrapped Uher Reference No1 power amp (meters were originally driven by the Toshiba TA7318P IC) now I want to use these VU meters with the PeeCeeBee V4H power amp that I am building, I don't want a true VU meter function but just a nice bouncing for visual pleasure, I wonder if this is a suitable driver for my project NEW upgraded edition OF TA7318P VU Meter Driver PCB Board Stereo module | eBay
Can you ascertain the sensitivity of the meters ?
It's easy enough to do with a battery and a high(ish) value pot. You'll need a multimeter too.
Simply adjust the pot until the VU meter is at full deflection and read the current on the multimeter.
Typically they are usually only a few mA but this can vary. The battery voltage is unimportant as is the pot, you are only trying to measure the current through the VU meter at full deflection, however do bear in mind that you may only be after a few mA.
I see, then I'll try to test the meters later tonight when I am at home and I'll report back, what measurments should I take with the DMM?
Or I can measure the already set values on the original trim pots as I have the whole pcb of the Uher.
Oooh that looks sooo nice. The unit you linked has pots on its, which I assume is for sensitivity settings. katieandDad might be on to something. These are actualy watt meters, so they are on the output side, VU meters will be on the preamp side, if I remember correctly
The only problem with a non-VU approach is that we usually listen to our music at quite a modest (surprising low) volume level. 5W RMS is actually reasonably loud.
If you build a circuit to use the meters up to the 300W on their scales, they will hardly move in normal operation.
In order to achieve a decent result you will need an amplifier with a Log characteristic.
If you are intending on driving this circuit with 300W then you will need to pay attention to the attenuation resistors on the input of the driver amplifier.
The part quoted in the OP only has a rating of 3W.
To move at normal (very low watts) level, you need a compressor, like in original Uher.
That driver from ebay look suspicious, that IC is not TA7318 (compressor IC). I will not buy that.
TA7318 is SIL9 and that IC is DIL8 and with erased label.
Those four diodes suggest that is only a full wave rectifier and opamp (erased label IC).
Better search for driver with real TA7318.
AGC is not used in the VU or Peak meters.
