Anyone have a schematic for this amp?
Someone has been inside it before and I saw a lot of wrong parts already .
When asking for Rockford diagrams, it's best to give the PC#.
http://www.bcae1.com/temp/rockford - power250m2.pdf
The original gate resistors are 22 ohm .
I’m gonna use 3205’s in the power supply .
Since I don’t have 22 ohm resistors on hand and trying to finish this amp is there another value I can use ?
I forget which 2 diodes do I lift to disable the protection in 1 of the channels ?
300 series parts
300 series parts
Lifted both 1 at at times no change .
I will have to go through the channel to figure out why it has distorted audio and won’t bias
Is there an easy way to check the components like voltage wise or do I have to ohm everything out I’ve went through the channel and everything is testing good but I know a transistor or resistor is bad or both . Since I get very distorted output and e channel will not bias
Inside the feedback loop, one bad component can cause the voltage on all other components in the loop to be off.
When checking transistors, what are you checking?
- General Interest
- Car Audio
- Rockford Fosgate Punch 250M2
