Razor RZR1-2500D
Hello, I'm trying to repair an Acustik power amplifier.
Model RZR1-2500D
The problem is that when the volume is increased beyond a certain level of sound demand, it intermittently goes into protection mode.
I have no idea what causes this type of failure.
HFP50n06
FDP2552
The amplifier has integrated circuits such as
SG3525AP
LM393
IRS2092s
Can someone help me with how to address this problem? Please.
Thanks for you attention
Will it shut down when driven to clipping with no load?
with and without load. causes the fault
What about with a load significantly higher than its lowest rated load?
The fault persists
Could it be due to voltage drop at the 12v input (low voltage protection)?
The voltage variation is from 13.79v to 13.62v with a consumption of 18amp with a load of 2 ohms in audio output a tone of 60hz
Without a load @ 13.78v
250 hz : 36.9 ACV ( 37 acv to 42 acv shut off ) 43.5 ACV again works
200 hz : 36.8 ACV ( 37 acv to 47 acv shut off ) 48.2 ACV again works
150 hz : 36.9 ACV ( 37 acv to 39 acv shut off ) 40.6 ACV again works
90 hz : 36.4 ACV ( 37 acv to 39 acv shut off ) 40.1 ACV again works
80hz : 35.6 ACV ( 37 acv to 38 acv shut off ) 39.6 ACV again works
60 hz : 31.9 ACV ( 32 acv to 38 acv shut off ) 39.5 ACV again works
With a Load 2 ohms
250 hz to 80 hz not shut off , except when changing tracks on the USB player.
70 hz : 31.9 ACV ( 32 acv to 34 acv shut off ) 35.8 ACV again works
13.78 DCV normal . 13.58 DCV shut off
60 hz : 31.9 ACV ( 32 acv to 34 acv shut off ) 35.2 ACV again works
13.78 DCV normal . 13.63 DCV shut off
