I'm a beginner when it comes to TL's and horns. What are some good threads, guides, videos, you recommend that cut straight to the useful facts about these enclosures and designing them with Hornresp, which I have not yet downloaded.
I have seen a few different configurations, and am curious how they generally compare and the pros and cons of each: the driver having a sealed back, a ported back, one side open to the outside of the enclosure, one side exposed near the rear of the inside of the TL, and one side exposed toward the front of the inside TL. It would be interesting to see a phase comparison of the opening of the TL vs the other side of the driver of these different configurations over the usable frequency range and a little beyond, if anyone has done some of those tests.
Also, are there any general rules of thumb regarding the way it is folded to save space: expanding opening (which I assume would increase sensitivity and harmonics), constant size, decreasing area (which I assume would decrease harmonics), smooth bends vs hard right or even acute angle bends? I assume right angle bends would set up harmonic resonances, while acute angles may trap them and prevent their escape while decreasing efficiency.
I realize the potential complexity involved, but I'm trying to just learn the basics.
http://hyperphysics.phy-astr.gsu.edu/hbase/Waves/opecol.html#c1
I don’t think these low/long 1/4 and half wavelengths care much about the shape of a turn or bend in the middle of the ‘pipe’? Unless you had a whole bunch of switchbacks that ate up dB from forcing things to scatter vibrations back and forth (?)
If you move the driver to 1/3 in the pipe you can prevent an annoying resonace (at the 3 x Fb) but I don’t think folding the pipe 3 x has a measurable affect on that resonace (??)
I found this post about qts helpful:
FWIW, I've designed and built many TLs and I've gotten good to excellent results with drivers having a Qts in the range of 0.35 to 0.50. Drivers with Qts outside of that range sometimes surprise me with acceptable results. The key in my opinion is to shoot for a system tuning frequency equal to fs when Qts is equal or close to 0.40. If Qts is higher than 0.40, the optimum tuning frequency will be lower than fs. If Qts is lower than 0.40, the optimum tuning frequency will be higher than fs. Also, unless you're doing an ML-TL which has essentially a constant area throughout the line's length, I prefer a negatively tapered TL with a taper ratio of 10:1 or greater. But I've also had success with a line that's both tapered and mass-loaded (see attached).
Paul
FWIW, I've designed and built many TLs and I've gotten good to excellent results with drivers having a Qts in the range of 0.35 to 0.50. Drivers with Qts outside of that range sometimes surprise me with acceptable results. The key in my opinion is to shoot for a system tuning frequency equal to fs when Qts is equal or close to 0.40. If Qts is higher than 0.40, the optimum tuning frequency will be lower than fs. If Qts is lower than 0.40, the optimum tuning frequency will be higher than fs. Also, unless you're doing an ML-TL which has essentially a constant area throughout the line's...
Beware, if you read 7 articles about QWTL you'll end up with 8 opinions
Starting point
http://quarter-wave.com/
From here you'll find sufficient references to other articles to keep you busy for a while.
Indeed Hornresp is considered the right simulation program for TL design. Others exist in the form of spreadsheets of MathCAD programs.
Starting point
Hello guys!
I have been reading some TL-articles from MJK and also in Vance Dickason's Loudspeaker cookbook (7th ed.).
Many interesting things in there that I didn't know, I was quite delighted to learn so much stuff. On my quest to keep learning I want to ask you guys:
Does anyone of you maybe have some articles written by MJK or, preferably, Augspurger on the TLs?
Especially Dickason's Loudspeaker-cookbook made me very interested in Augspurgers side on this. To be more precise: The articles he wrote for the "Speaker Builder" Magazine in 2000 where he contributed one article per...
- irishrOy
- Forum: Full Range
These descrioptions don’t get your point across. sketches?
Do read King & Augpurger.
A transmisison line is a box that has an aspect ratio such that one dimension is considerably larger than the others (ie a pipe), with a driver mounted somewhere along the pipe and a hole in the box.
dave
One thing I don't understand yet is why the different positions of the back of the driver being exposed to the path of the TL like as seen in these pics with some deep inside, while others are near the mouth.
But I do realize now that in general a TL is any enclosure with a significantly long port or perhaps even sealed dimension.
It's because you posted the wrong examples, as those are all horns.
The long one has a resonator chamber, the fluffy white sound absorber and the slits right at the sides of the throat seems to indicate that.
So you don't have the so-called direct radiation but ...
Ahhh, that's because you posted in the subwoofer sub-foeum!
Indeed that always seems to me very suspicious...I mean why you want to split the audio band and discuss about the first octave(s)??
Ah ah ah
So those are all subwoofers...as you don't hear any mid-treble coming from the mouth of the horn.
TLs don't use a compression chamber..
Or: TLs use a compression chamber that is a LP
Indeed the software...
Clever...
But it mimics the AI approach to the "real world"
Ah ah ah
Clever...
What's the advantage to using transmission lines? In a full range and sub only context, whether straight, or tapered. If I'm not missing anything, it looks like for the same volume there's a general 3dB louder bass compared to a BR, and much less chance of chuffing.
I've had another thought pop into my mind: though the harmonic damping techniques used today are probably sufficient, would it be better to have 2 or 3 TL's per channel tuned a little differently, so the harmonics get smoothed out by the sum of the TL's?
None of those are really TL designs. The last one is a tapped-horn, which is similar to, but not the same as, a TL. The others, I'm not really sure what they are.One thing I don't understand yet is why the different positions of the back of the driver being exposed to the path of the TL like as seen in these pics with some deep inside, while others are near the mouth.
View attachment 1476965 View attachment 1476966
TLs really aren't all that difficult to design. Have a look at my TL page for a process you can use to design one. The offset-driver approach extends the useful bandwidth of a TL. A properly designed will be just a little larger than a vented box with the same Fb and passband response designed for the same driver. The advantage of a TL is you get to choose where the harmonic resonances appear and their subsequent impact on the overall frequency response.
My TL page - https://www.diysubwoofers.org/tls/
FWIW, I found it's easier to start with the box and internal layout you'd like to use and then adjust it based on the predicted response from Hornresp, rather than starting with a Hornresp sim and then trying to translate the sim into a box. My BOXPLAN workbooks help to ease the burden a little. 🙂.
- Subwoofers
- Question about Transmission Lines
