Proof that anyone can, Unity Horn
Hi ,
Nice MEH project!
What is the distant as shown?
Would you share the STL?
thanks
I will be sharing the STL once I am finished.
Reactions: Naturlyd and Wright
I'm still working on this, I need to build new cabinets to house the final design. I'm also thinking about ordering a KABD and making this a portable blue-tooth speaker. Anyways, here is the STL! I want to make an organized write up but I just haven't had the time. This simple/cheap MEH idea turned out to be a lot more work than expected.
Here are my DSP settings. I still need to take polars with these.
Tweeter (Inverted Polarity)
Gain: -3db
High Pass Filter: 1400 Hz, Butterworth, 24 dB/oct
Low Shelf EQ: 4200 Hz, -9.2 dB, Q 0.9
Woofer
Gain: 0db
Low Pass Filter: 3000 Hz, Butterworth, 6 dB/oct
High Pass Filter: 65 Hz, 12 dB/oct (slope type unspecified)
High Shelf EQ: 450 Hz, -11.5 dB, Q 0.9
The high pass on the woofer is optional but recommended. I turn it off for low volume listening. At higher levels it reduces port chuffing.
Thanks for your work, making MEHs accessible is a very noble thing to do 🙂 I saw that there a different versions of the XT25 tweeter, which one do you use? is it the Peerless by Tymphany XT25TG30-04 one from the picture?
Thank you again!
@amori yes the Peerless by Tymphany XT25TG30-04 is the one I am using. There are other tweeters that will also fit but untested.
XT25BG60-04: The dual ring version. Will probably have similar performance. It's a lot heavier though so I would find a way to support it in the cabinet if possible. It will also require a deeper cabinet.
DX25TG59-04: The dome version. I really want to try this one. From what I have researched, the extra surface area of the dome could assist in achieving a low crossover frequency. However, I am skeptical on the high frequency performance > 10khz
Other candidates that might work but would require mounting/throat modifications: DC28F-8, RST28F-4. I wanted to try a bunch of these, but I quickly realized that I could buy a nice set of compression drivers with the money instead.
If anyone is interested in experimenting with one of these tweeters I can give you a file with updated mounting holes.
Reactions: amori
I’m printing with a .4mm nozzle. I like the smooth finish it gives me, almost no sanding is needed. I’m sure epoxy would be better. But super glue has been good enough for prototyping and it dries much faster.
Note: I am using a textured bed, which gives the glue surface a nice rough surface to bond easily.
I know in one of your threads you recommend using high infill to avoid resonances. I found that this wasn’t the case from a study on youtube. For strength I use a higher wall thickness of 4 layers.
Considering how much plastic I’ve used on this already. Keeping the print under one kilogram is a huge plus! I’ve probably spent more on PLA than anything else combined. There’s a huge pile of horns in the corner of my office. Yet, I got the port hole distance right on the first go.
Here’s a link to the study:
3D printing infill resonances.
I think that if he had used an accelerometer rather than a microphone he may have found quite differently. The shape of the surfaces would also strongly affect resonances and more importantly, how sound gets radiated from surfaces. His example wasn't a horn with a driver mounted on a wall. His test may show not much radiated effect where the mic was pointing at with his tight small box, but not really anything that could be generalized on. When I tested, the issue was way past just measurable (with accelerometer), it was unlistenably buzzing with only moderate infill. Which was sad, because those were my cleanest horn prints and had to be thrown onto the trash pile.
I remember seeing that video a while back and tend to agree that the data is probably not applicable to MEHs. There's just a lot more energy being transmitted into the horn as you start going lower in frequency in a MEH, so the potential for material induced nonlinearities increases drastically.
I'm curious if there's interest in a sort of standardized testing rig for getting good repeatable data on that topic though. Something like a horn that could be compared against a plywood control to determine exactly what effect material/infill density/infill pattern has acoustically.
I have a CNC, several 3d printers, and a load of different drivers so would be happy to lend services there if there's some consensus on exactly what data would be useful to capture, and what a test device/platform might look like.
I think that if he had used an accelerometer rather than a microphone he may have found quite differently....
Sigh... I'm convinced. I hear a very slight buzz at higher volumes. I was thinking it was my tweeter and have been driving myself crazy trying to fix. Will order a bigger nozzle and see if it improves things at some point. Maybe I can print it in ABS and give acetone smoothing a try.
I am also planing on gluing 6mm plywood triangles to the flat areas around the horn to fix what I got. That might help a bit.
I've seen some stuff about filling a hollow print with either expanding foam or plaster of paris. Most stuff I print needs some infill to hold up the top as it prints, so I'm not sure if theres a infill pattern that will allow that to work. I'm considering experiments tho.
I'm working on an experiment using a speaker enclosure filled with plaster of paris mixed with PA glue vs. one with 40% in-fill (per the YouTube video you all have been talking about). This is for an Atmos in-ceiling speaker. I've got both printed out and one enclosure filled with PoP+glue... I just need to find time to measure both. I don't have an accelerometer however...
Anyone who wants to jump in on my thread and give me hints on how to measure these to best effect is welcome as I'm not sure the best way to do this...
I’m very interested in seeing tests on different infill settings and filler materials for 3D printed speakers. I’ve been considering filling my MEH horn with either a epoxy/sand mixture, plaster of Paris, or even silicone, but I haven’t started any proper research yet.
I know about someone who just 3D printed a mould and made his horn in a kind of geopolymer based on clay. But he is a chemist who can make his own. Most of us won't have that knowledge or tools.
But i like the mall id and make it with that mall in an inert material. We just need to find the right one and how to make a horn with it. I don't like those printed horns, they always seems to be very fragile and resonate often quiet bad.
This is a non-trivial question, as I expect a rattling 3D print noise would fall under the category of "Rub and Buzz" (or maybe "loose particle") which is challenging to detect. Klippel, Audio Precision, Listen have tests for this, but I'm not aware of one in the free domain (maybe it's out there and I just don't know?). Simple Frequency Response and THD don't catch it. High Order Harmonic Distortion is one test. You could see it perhaps on a FFT, but then you have to be at a stimulus frequency that excites the fault...
https://audioxpress.com/article/speakers-the-evolution-of-production-line-rub-buzz-measurements
To cut back on potential vibrations, I think a mixture of wood and plastic would be an effective way to reduce them. All angles are 45 degrees so assembly would be pretty simple compared to making the whole thing out of plywood. You could make all these cuts with a circular saw and a circle jig, tools most people seem to have in this forum.
The phase plugs bottom half is plywood to reduce vibrations, with a printed cap on top to reduce chamber volume. My only complaint is it removes the threaded insert mounting option, which was super convenient.
Another possibility to check is whether the mids or woofer surrounds (or cone itself) are crashing into their openings to the horn. When things get wild and poorly controlled things warp and can start hitting. I figured it out when I ran into that problem by making some thin spacers to slightly move the drivers (midranges in my case) back slightly. That particular weird buzzing went away.
I fixed the weird buzzing and have my first pair of horns running. New cabinets and a stronger print fixed the issues. You notice on my first post that the horn has a crack on the edges. I'm pretty sure that was causing bussing along with a loose screw in the banana plug plate. The new cabinets are also a LOT more sturdy with doubled up 18mm ply. I still need to do a couple more coats of paint but I was so excited to listen I haven't finished yet.
Gain: -6db
High Pass Filter: 1400 Hz 1200 Hz, 24 dB/oct
Woofer
Gain: 0db
Also I made a mistake when I published these dsp settings. I wish I could edit the post... The tweeter should NOT be inverted and I ended up lowering the XO frequency a little bit now that the buzzing is confirmed to not be the tweeter.
I will be doing a measurement day outside as soon as I can. Feel free to critique my results
Reactions: szach00
