Optimal bias in push-pull EF output stage: textbooks and reality
Under bias would happen if the Vbe multiplier compensation got warmed and then loud music stopped, allowing the outputs to cool.
I suspect the CFP configuration is less vulnerable to this.
Actually CFP is MUCH worse than EF2 for this. I've described a test which shows THD goes up to maybe 1%; all nasty crossover stuff for a minute or two, until the amp cools to 'normal' temperature. Bob Cordell has reported similar results.
That's not to say it is impossible to design CFP O/P without this behaviour .... but I haven't found any in real life.
There's another evil in CFP O/Ps ... at least as Self does them.
In one version of his early books, Self shows EF2 THD drops with level but CFP THD tends to increase at low level below 1W. (This is on top of the usual measured 'increase' due to S/N) I asked him to investigate this further for a later edition but got no answer
@PMA - I realized that making the simulator lopsided would be easier than straightening the amplifier.
I adjusted the parameters to match your 23mV measurements in post #47. I found that I could replicate the distortion spectrum through the fifth harmonic by using 0.1 ohm and 0.34 ohm emitter resistors. This mimics NPN/PNP Hfe mismatch times source impedance in the amplifier.
Code:
harmonic %         dB
0        0.004641  -86.668312
1        99.992177 -0.000679
2        0.001541  -96.245626
3        0.000031  -130.180912
4        0.000289  -110.772811
5        0.000033  -129.681139
6        0.000104  -119.652462
7        0.000033  -129.573269
8        0.000042  -127.470751
9        0.000025  -132.000111
thd 0.001573%
And the optimum bias is... more is better.
The curves are for different peak amplitudes in volts.
I feel good about the simple model (this model has negative feedback).
Ed
Reactions: hbtaudio
Actually Ed ... you do. Or at least borrow one.
Ebers-Moll is obviously correct, but there are so many other factors and assumptions made in simulations. A simulator is much more useful in an integrated IC, like an op amp. Outside of that you have too many factors to take into account.
I matched the parts in a Symasym. It was a "utility amplifier" I didn't expect huge things from. I also used different devices for outputs and drivers. My minimum THD point was 5 mA of bias current at 1 watt into 8 ohms. The crossover notch disappeared before that value, I built four, they were all consistent. Non-inductive wire wound resistors for emitters. Many amplifiers I see work the best from 10 to 30 mA of bias current. Some need more. Some designs are simply never happy, typically "designed by ear" models. Matching the outputs (multi-output) and drivers reduces crossover notches.
That is real life, measured performance. No assumptions, no "should be". Real life.
I am okay with getting the first-order effect right and designing in a manner that minimizes all other effects. Audio is just an old hobby and I already have enough amplifiers. 🙂
ETA: Here is another check. The simulator needed a loop gain of 700 to produce the right absolute values. @PMA - What was the actual loop gain?
Ed
Reactions: hbtaudio
without taking VAS drive circuit (voltage, current, something in between), without taking FB action and compensation into account - is an oversimplified nonsense
Yup, already addressed the issue and clearly stated.
If the amplifier frontend is not anything special then 30 to 40ma is all that is needed.
I am taking the " VAS" into account. Majority of all the 2nd harmonic in these test you show is the = VAS
THD will never change much, until that 2nd harmonic goes down.
Also mentioned THD in bias is more observed at higher frequency.
This particular amplifier, isn't good enough to observe any notable outcome.
Since the frontend and compensation wont allow any higher bias to show high frequency improvements
Your observations of lower signal and higher signal THD in this particular amplifier.
Is not taking the pre drivers bias current into account as well.
And contributing as well to most the observations.
The effects of crossover distortion at low and high signals, and wingspread graphs 3D or not
is well known.
Post#1 shows MJE15030/31 they are also = under biased
Oversimplifying is not a " big deal" your measurements show .0017 and .0016 THD
And including noise, has = no change
You are correct, at low power and high power there will be notable change in THD
from 40 to 120 ma.
If the amplifier loads the VAS to much and the bandwidth is limited.
At higher power expect 100ma + bias to be no benefit. The VAS loading creates more THD than any bias will fix.
Exceeding 40ma is nothing but heat and has no benefit.
Again especially at high frequency, where high bias actually has use.
Which has been and will always be 100 ma which will increase to 118 to 140ma over a timeline
depending on the thermal tracking.
Me saying 100ma then posting 105ma yadda yadda yadda.
It all changes over a timeline, and people coming up with mystical magic bias circuits.
Can go waste time with that too.
The only way to use CFP is strong A-class.
Just imagine, last OPS device are switched off, local intrinsic in-stage feedback loop becomes broken, driver interacts with load straightly and OPS input resistance drops dramatically (two orders magnitude) overloading VAS.
No way to correct such a high-frequency effects in a global feedback loop, it just lacks bandwidth.
CFP should be avoided in any AB-class designs.
Code:
harmonic %         dB
thd 0.001573%
Ed
From those curves i would say that the optimum is at 35mA, there s not much that is gained at higher bias, and more NFB
easily bring you at those lower levels, indeed commercial japanese amps using fast devices like the 2SA1302/2SC3281
were usualy biaised at 30-35mA.
Indeed then the noted observation at " low levels" like one watt
100ma would improve distortion measurements.
Then also as noted with a fronted that allows it.
High frequency also improved.
Any issues with the second gain stage in the frontend solved with EF3
and with CFP a additional folded driver introduced.
The current sources operating at DC dont give a darn.
Folded drivers bootstrapped to the output. Dump any other nonsense
straight to the output.
Sounds like Lochonthi solved most these issues with what he did for the JBL amplifier.
Including the symmetrical 2nd gain stage.
even though both simplified, basically Hitachi figured it out further to improve it with minimal parts.
The overall device quality was the only threshold Bart was against.
Yes, one has to design the differential pair and VAS for similarly low levels of distortion. And yes, ripple will be higher. But the same techniques that make class AB better can also make class A better.
I don't plan to build a class A amplifier. My point was to demonstrate the silliness of the THD wars by being even sillier.
Ed
Silly for sure. With you on that, have done it too with Class A , and agree never to be built.
It strangely does and doesn't make class A " better" at the same time.
It just further enforces the actual original claim of being superior for low distortion.
Actual low distortion Class A would be a unbeatable sea of grass for harmonics, buried in the actual noise floor.
The noise floor itself would be the limit.
And entirely within reason, not complicated to achieve. Just too good for peoples imagination to not accept it.
As being the end of where you can go.
Reactions: anatech
They probably made the heatsinks too small. The bias will drift up more than with bigger heatsinks.
I found ultra-low distortion class A to be an interesting exercise because the differential pair and VAS distortion can no longer hide behind a class AB output stage's distortion.
Ed
To summarize:
Pavel M. is tackling a hot potato here - and the essence is and remains the inadmissible simplification of an apodictic statement that began in the Wingspreed Diagram. Namely the assertion that there is an optimum base-emitter bias-voltage which, expressed as a quiescent current of 100mAdc or 22mVdc as a voltage drop ..!
The topic is not quite that simple - and must always be understood in the overall context of topology.
What happens in terms of circuitry when our signal passes the zero crossing, i.e. rising and falling, that is the question.
Of course, the push-pull emitter follower can be considered separately. Just as D. Self has done. However, this is not an absolutely valid law.
Optimal bias voltage is nothing more than a question of definition - in other words, it also depends on the context.
HBt.
Reactions: jan.didden
The idea is simple.
In class A region, everything is perfect. Let's put this situation aside.
At high current, the ouput impedance of the push pull EF stage should be dominated by degenerating resistor Re, not by (Vt/Ic), as Vt/Ic is not linear. That requires the minimun bias current larger than Vt/Re.
The myth is whether there is an optimal bias point or it is just the more, the better.
I lean toward there would be an optimal bias point. The size of class A region (or crossover region) play a big role here, too. Take CFP for example, the optimal bias of CFP is around 10mA to 20mA. CFP has very high gm due to local NFB. The value of Re solely determines the output impedance. A small cross over region impoves THD by a lot. Of cause, the size of the region is relative to the output power you mesure at. In some cases it is too big, in the other cases it is too small.
