Very simple MOSFET preamp/driver
I built this circuit back in the year 2002 and I used it as a driving stage for my class A power buffer PM-A1 (gain 1x, 30W/8ohm). It was working very well with quite good parameters, as can be seen below.
(D1 is a Zener diode 6V8)
I am showing above the THD+N plot (1kHz, BW40kHz) to include noise part as well. This is often omitted, unfortunately.
Loopgain stability is perfect, with 87° phase margin.
Hi, PMA!
Why do you actively drive base of Q1 with Q2 (tracking idle current of R12) while more sensitive to common mode error M3 was kept without Early effect compensation?
If you replace R15 and R9 with RCR-networks - this will provide you with effective soft-start.
The IRF9630 has a worst case +/-1V variation in threshold voltage according to the datasheet - that doesn't bode well for the amplifier output offset voltage. Even if you match them MOSFET threshold voltages change with age due to ion migration in the gate, and with temperature.
