Or is it black magic. 🤣
I can't remember now if the PCM1702 ran at 384k. I think so, but I could be wrong.
@eclipsevl You know how they quaranteed this specification on AD1865. They made testing on slower BCLK, only 18-bit FS LRCK (768 kHz * 18 = 13.8 MHz for BCK) - only mono.
So does the AD1862, 16x oversampling in datasheet ... that is 768 kHz * 20fs (only mono) = 15.36 MHz for BCK
One thing, it is states it's minimum clock rate 13.5Mhz for ad1865 😉 So they left quite a large questwork of maximum frequency. In ds, figure 13, there is 16.9344Mhz xin with cdx1244 digital filter. So higher is definitely possible.
Fired it up. Plays music. But only through the Left channel. Measured AC voltage out from the D1 RCA's out, I can see a half volt on the left and negligible on the left. Thinking I may still not have the JLS I2s over USB pins correct.Thanks @zoom777 and @eclipsevl. Added Pin 9, removed J4 and closed J3 and J6. Now on to fixing the negative rail of shunt regulator powering D1 output, the final task before first full fire-up. Appreciate your help!
Resolved dead left channel. My error, neglected to solder the # nine female receiver header pin on the underside of the DAC board. Next step, burn in and optimization. Need to try changing R4 on the D1 from 1k8R to max 2kR, as my system is low gain.Fired it up. Plays music. But only through the Left channel. Measured AC voltage out from the D1 RCA's out, I can see a half volt on the left and negligible on the left. Thinking I may still not have the JLS I2s over USB pins correct.
He is using NP D1. Such a drastic change will affect the operation of the other area of the circuit, and there are other resistors to be changed in the correct ratio. Iirc, there is also a need to raise the bipolar voltage to somewhere like 40V to maintain the drain current of the MOSFETs to allow higher IV resistors.For R I/V I recommend the 3.01k Dale RN55D. For the output resistor, the same Dale 22ohm.
I changed a few things that were mentioned in my last previous posts. I'm still experimenting with r8 r9 and c15 c25 etc. It's better but the differences are subtle. I'm using Burson V7 Classic. I'm thinking about a tube stage. Will it give me a noticeable improvement? Is it worth messing with? Or which solution to test first? Something simple to build.
Please share the group buy / swap meet link if/when you sell. I've got a pair of PCM63P-K that need a home. 🙂
- Digital Line Level
- DAC AD1862: Almost THT, I2S input, NOS, R-2R
