JBL 4333 (ish) (Kinda) build?
@weltersys some of finds. The 2231a cones are original, but the foam surrounds have been replaced, and poorly. They will have to come off and be redone.
Hello
How did you determine they are original? They are not faded at all. Unless they lived in a box or are a recent re-cone. There hasn't been that many kits and they go back to the late 70's with the 2235 as a replacement. Matter of fact the re-cone for a 2231 wound be a 2235 kit. If you can measure Fs 16Hz 2231 and 20Hz 2235. I have measured fresh re-cones of 2235 and Fs is damn close the pair I measured 19 and 20Hz.
The 2420 looks like a Ti replacement. Could be 2421 but doubtful as they are no where near as common as the Ti's.
Rob 🙂
@Robh3606 - you raise a good point. I had shown gentleman who has some expertise the photos attached - it was he who told me the numbers aligned with original JBL parts. Given his line of work and history with JBL, I trusted his comments. I'd be happy to hear other thoughts though.. I'd rather know what im dealing with. Thanks!
Reactions: Robh3606
Just did a quick search at Lansing Heritage. Those are the correct cone numbers. In addition the 2231H/136H and 2235 use the same basic cone. I have attached pictures of both use the same mass ring the difference being the suspension. The easiest way to know is measuring Fs so you can tune your reflex cabinet using the correct T/S parameters. 2235 kit not installed
Rob 🙂
Good idea those older alnicos can be a little light on flux. Also the power handling and x max are different both improved in the 2235 kit so it is important to know or your sim's won't be good. Hope he get's it working so you can start your project! Have fun that's a great driver set.
Rob 🙂
Reactions: Coelacanth
no, but surely deplietion of flux over time is common enough with alnico - these are now 50ish years old... may have some impact?
As weltersys points out it depends on use and how hard the driver was used. Take a look at the second post in this thread. It's Greg's post so it real world experience talking with what the consequences would be. Lightly used no issues, don't know the history could very well be. Talk to the original owner he might know.
Rob 🙂
https://www.audioheritage.org/vbulletin/showthread.php?4031-The-Great-Alnico-Ferrite-Debate
This is an interesting idea about re-gaussing. Magnet material, storage conditions, use of driver, and so forth would have to be in an extreme condition or environment to make any real changes, I suspect. The rolls, cone, spider, and voice coil leads however, all have some influences from age.
Actually no, you don't have to cook the coil it can happen under normal use depending on driver design, underhung vs overhung, amp power available and listening habits. Read the link I posted about De-mag of legacy JBL alnico drivers.
Rob 🙂
