PSU Help!
Hi, I need dual rails or a negative rail in addition to the single + 12v to power some op-amps based filters ( band pass for LED Spectrum analyzer ).
Power consumption I assume will be low.
I would like to use a " brick wall adapter " that outputs only a single rail ( 12 or 14.4V at a few amps ).
I found this setup with 7812 / 7912 , anyone used this ?
Thank you,
- Bruno.
EDIT:
I miss read the ic, seems to be " R-78CKxx-05 " can a 7912 be used there ?.
Definitely not.
What you want is a small DC/DC converter that gives +12, -12 from a 9 to 15 volt input.
Like these. The search function shows 1000's of different types so you will have to find one. I've tried and given up 🙂 These work well and are easy to use.
https://uk.farnell.com/c/power-supplies/dc-dc-converters/isolated-through-hole-dc-dc-converters
The output of these is fully floating so no ground issues.
Reactions: xXBrunoXx
They are good, I've used them for various things in the past.
Make sue you get the voltages and current ratings you want. There are so many to choose from that searching the sites for what you want is difficult but they are cheap and readily available from lots of places.
All they need to work well are small caps at the input and across each rail fitted close to the converter. Do not fit large caps across the output rails, they don't need them and they can stop it working properly. 10uF is a typical value, don't fit bigger, it doesn't them and they will cause problems if you do.
@Mooly Simplest solution without waiting for shipment , would be making the op amp work on single supply like this:
any drawback ? besides it will run on lower voltages +-6v , and needs blocking caps on both input and output.
C5 looks big in relation to working into 200k (0.08Hz -3db
Using this calculator. for the filters, haven't picked values yet.
Even 0.1uF works. maybe 1uF for all input caps caps . or use smaller value for higher frequencies.
There will be 10bands.
- So , using a single rail supply is fine. will +-6V be enough to output 2.5V ? ( 2.5v for max amplitude , last LED. to LM3914 ). I can't find output voltage swing vs supply voltage for NE5532, 4558 seems to output +-4V at +-5V supply , seems a bit optimistic tho.
+-6V , even 2v per rail loss, it's +-4V so around 2.8Vrms ?
12 volts (doesn't matter if it is 12v single rail or -/+6v split rail) for the opamp will get you your 2.8 volts rms you mention. If you try going a bit lower on rail voltage then the choice of opamp becomes more critical.
The 5532 is fine but is also quite a high current consumer which you don't want if using a DC/DC converter.
Looks like you are using one half of the opamp. Why not run in parallel to get more current.
I never did run op amps in parallel. but I've seen the approach on the forum.
I need a buffer ( with gain ) that runs the 10 MFB band pass filters, I'm assuming one simple op amp might struggle.
Or use a buffer unity gain , and make the filters with gain ? like 5 or 10 instead of 1 ?.
That circuit should be fine from one opamp. The simulation will show the sort of opamp output currents involved... they should be quite low.
400 ohm as a load is high enough to drive from a parallel opamp setup with the right opamp. That would simplify the circuit to essential a few components. This would translate to a single rail design easily enough. Shown as unity gain but can be made to have gain in the usual way.
I'm not sure if I need two voltage dividers, on per amp , or one like this will do :
and the output caps before or after R10 / R11.
