I'm currently building these for my Philips AD1256. The backs will be glued and nailed shut while the front will screwed down and able to be swapped out. Currently my built feels really strong and sturdy. I will add 2 cross beams to the middle and glue some butyl pads for dampening. Is a vertical brace necessary? I don't want to add too many braces that will affect the overall volume. Too bad I didn't consider bracing in the beginning. Any recommendations will be greatly appreciated.
Cross braces are good. If you want another opportunity that doesn't use much internal space, you might think about external constrained layers. The back is a larger panel and can be CLD and attached to the front since the front has big holes cut into it.
Ideally braces shoud connect 4 sides and fill the corners. In a cabinet that aspect, braces are best placed vertically.
dave
dave
Hi! Could you clarify why vertical?In a cabinet that aspect, braces are best placed vertically
I'm currently resolving some resonances and I've created horizontal braces using that popular "window" and a U shape right behind the woofer to connect all the 4 sides.
This is a 10" loudspeaker for using as a monitor in a studio.
Back panel is screwed and glued to the bracing.
Could you comment?
Thank you!
Bigger number is better.
In words: The aspect-ratio of the subpanels should be greater tghan that of the panel being braced. SubPanela ≠ SubPanelb
Could you comment?
It could be done better.
This is a biggish box (135 litre) but is well braced.
I also like to brace the driver across 3 more panels than just the baffle. Smaller box needs fewer braces.
dave
Dave, how do you apply that brace with bass reflex box, lets say Scott's double chamber or any box with back reflex tube?
Ok! Got it. In my box shape example, although horizontal bracing is effective (it dows bump the resonance to a higher frequency), the resonance frequency would go even higher with vertical bracing due to the final aspect ratio of the sub parts.In words: The aspect-ratio of the subpanels should be greater tghan that of the panel being braced. SubPanela ≠ SubPanelb
Thank you!
It's not the aspect ratio per se, but the smaller dimension.due to the final aspect ratio of the sub parts
Both the boxes i posted are vented.
Here is a big one with basic bracing (GPA/Altec 604), Vent out the bottom. Paid plan so small pics w/o dimensions
Notice the lack of a brace parallel to the baffle right behind the driver.
dave
Yes, the smaller dimesion is the primary mode and smaller = higher frequency = good.
Take a rectanular pane (taller than wide)l, divide it in half horizontally you get 2 more similar dimensions, not nearly as effecive.
dave
- Full Range
- Bracing Help
