Yes another 2A3 design I am ready to be judged
Hi
My first try on a tube amp
Stuck at the power supply
Andreas
The B+ and B++ from you PSU will be identical, not as shown in the amp schematic.
Looking at the curves of the 6N1P, the bias of the tube seems off. 2V / 200 Ohm is 10 mA.
Also, the grid bias of -2V means grid current will start at an input signal of about +/-1.5 V or so. I would recommend biasing at a more negative grid voltage (-4 V or lower).
With the 2A3 where the filaments are in ac???
Not necessary
The use of 6n1p in parallel is not a good choice
My opinion
Walter
Yes, I don't see any improvement in using parallel tubes when this isn't necessary. The 6N1P has driven output tubes in other designs.
If it were me I would use an ECC40 as driver tube. Better sound.
And why not use the book value for the 2a3: 45V, 60mA, 250V. So you then have 295V on the anode and a B+ of just over 300V. So why not just use a resistor load on the driver tube with the 300V B+available? For me resistor loads always sound the best, just choose a good sounding anode resistor.
It looks like you are over thinking this design. It's really much simpler.
No overthinking, just almost no cost object.
Yes I’m stuck, with the power supply
Duncan Amps PSUD2 is a great tool to plug and play options for the PSU.
When it comes to tubes like the 2A3, I don't see the point of reinventing the wheel. The greatest brains of our hobby have refined the different solutions. The exciting part is to review them, understand them, and be motivated to build one.
