How to fix these?
I have this speaker that stopped working and put my Yamaha into protect mode . I took it apart once but couldn’t find a x over or anything??? It seems a cord got loose and i attached it to the wrong spot .
Is that a speaker part of a portable boombox type system? If so it might be okay just not expensive so ask a friend to help. Do not try again if you plugged it into the wrong spot already or you key permanently damage the rest of your equipment.
sony ss rg70av htib I no longer use the Receiver it won’t plug into my led tv. I took the speaker apart once but never took a picture I don’t have any freinds who know anything about speakers.
The dodgy wiring through the cabinet needs to be fixed. At least have the twisted and taped part either inside the cabinet fully, or outside, not attempting to stuff two pieces of different cable through the hole 🙂 It's currently creating a short circuit, and you are lucky you have an amp with protect mode.
There is likely nothing wrong with the drivers.
I've extracted the speaker information for reference:
Front speaker SS-RG70AV
Speaker system: 3-way, 3-unit, bass-reflex, magnetically shielded
Speaker units: Sub Woofer: 13 cm cone, Woofer: 13 cm cone, Tweeter: 5 cm cone
Nominal impedance 6 ohms
Dimensions (w/h/d) approx. 215 × 325 × 255 mm
Mass approx. 4.0 kg net per speaker
Reactions: Kingnoob
The subwoofer will have a larger voice coil diameter than the woofer for increased power handling. This necessitates a larger diameter central dust cap.
P.S. It is clearer from the earlier picture of the subwoofer that its dust cap is concave rather than convex like that of the woofer.
Yes They have way better bass them my smaller insignias do. Which don’t seem to have any.
