Phonitor SE failure
It can happen to anyone I guess. Simply, that the phones were not plugged all the way into the HP jack on my Phonitor SE, and I was letting it warm up. By the time that wanted to listen music, one channel was out, and even a burning smell came from the amp. Taking the top cover off allowed me to quickly witness the trouble. Two of the SMD resistors on one channel board were burnt right off. I bought this directly from The Music Room a year ago, but highly doubt that they will be much good in this case.
Having said all of this, my two choices are to find a schematic for analysis, or have it shipped to a qualified repair shop. Oh boy. What say you?
SPL in Germany has contacted me and will make a ticket to assign a technician here in the USA. I am not looking forward to what will likely be an expensive repair, all because a headphone extension cord was not completely plugged in. Yup, will be getting a full 14 ft> headphone cable to replace it.
Truth be known, when the Phonitor SE comes back it is going to be immediately horse raced against the Whammy/SS-X combo that I am using right now. Some things in life are discovered by mistake, and this combination is one that I strongly prefer. Where there are weaknesses in with my headphones this combination is 'correcting' that. The real curiousness that I have is just how close, if at all, will these two compare? The Phonitor has what I just had to hear in a high voltage rail system for the circuit. I forget but it seems that it runs at over 100v. Their point is that it allows more headroom although it is very unlikely that any known cans would require that kind of reserve.
All in all, I felt that the Phonitor sound was a bit dry (accurate) for my taste. Reminds me of what I hear in some Sennheiser headphones. Certainly a great start in reproduction, but not an end goal for me.
The Phonitor is on its way back after a $400 repair. Wow, just like owning a race car with a flat tire. My 'fix' for not having an accidental short in the future is simple. Heatshrink (with adhesive!) to the rescue.
Nice story with a happy ending, although quite expensive.
Then you wisely planned the heatshrink with glue, but with time since the red connector seems to be conical it could even slip out again (crossing fingers).
To avoid running 400 more risks why not cover the two connectors up to their constricted end?
Just sayin'...
I thought the same but after testing the grip that this double wall heatshrink has on the connection, I couldn't move it even a tiny bit. There are indentations on both ends that allow extra grip. The real answer is to get a longer headphone cable, but I already have $100 invested in the 10 foot cable that is being used.
