I would like to build this amp and I need the power supply ( about 100v 200ma on the v-fet but a bit higher because the Output transformer primary impedance ) to be particularly silent since it is connected to a compression driver with 113db of sensitivity. I was thinking of using a CLCLC power supply (to have few mV of ripple) and I was wondering if the use of a Saligny power (HVHF in this case) could be useful.
My problem is that at most I can use PSUD II and therefore I have no idea how to model a power supply with a Saligny bridge. Any suggestions?
If you are concerned with ripple, just use a regular bridge rectifier in PSUDII for the simulation. The CLCLC filter will be the biggest factor in ripple reduction.
I don't know anything about the Saligny bridge, but the main difference between it and a regular bridge rectifier is probably the voltage drop. But for a 100V power supply simulation, not a problem. And the accuracy of the simulation will not be 100% anyways.
Many thanks, I'm really very interestedI built one and sold it. Would you like me to check my notes?
Dan 🙂
Hello pinholer, my curiosity is to understand ifIf you are concerned with ripple, just use a regular bridge rectifier in PSUDII for the simulation. The CLCLC filter will be the biggest factor in ripple reduction.
"Very low mosfet internal resistance improves dynamic circuit behaviour" (from datasheet)
can actually bring benefits in a class A amp. I ask because my knowledge is too limited
There is one way to find out. I think you will probably build independent power supplies for each amp (left and right channels) since you're concerned about clean power. So, use a regular bridge rectifier in one and a Saligny bridge in the other and compare the two amps in real life.
Me, I would put my money towards nice signal transformers first. I have actually built transformer coupled SIT monoblock amps and I just used regular bridge rectifiers.
It's an old project and as I recall I followed Michael's design to the letter. DM me and I'll give you my email address.
I will use input transformers 80% nickel manufactured by Dave Slagle and the output transformers are Tango Hirata so I agree with you. Time ago one of my friends build a monostage tube amplifier exactly with this schema ( input transf, tube, OPT ) with Telefunken EC8020 and he said was the most transparent amp he had ever buildThere is one way to find out. I think you will probably build independent power supplies for each amp (left and right channels) since you're concerned about clean power. So, use a regular bridge rectifier in one and a Saligny bridge in the other and compare the two amps in real life.
Nice iron. Which Tango output transformer will you use?
I had J&K Audio build me some FG-50S copies and they work great. I configured my output stage as a follower, though, so I used a Sony VFET voltage amplification stage, interstage coupled. I reused some old Magnequest RIT-5 interstages, leftovers from my tube daze.
I ran a quick PSUDII simulation and getting sub-millivolt ripple for the power supply is not too difficult with CLC and RC for local decoupling.
- Power Supplies
- Iron Amp by Michael Rothacher Power supply suggestions?
