A method for modeling cavity resonance in H-baffle (and other) woofers
I've often wondered if there is a way to model the cavity resonance that tends to affect the response of folded open baffle woofers, such as H-frames, and perhaps U-frames and even ripoles. I've looked for info on diyaudio from time to time, but until recently had never picked up anything very useful. I have tried Hornresp, but found it limited to a few specific geometries. (Maybe that's just a reflection of my small experience with it.)
My (poor) knowledge of open baffle theory has mostly come from reading Linkwitz Lab, and I have a vague memory of Siegfried suggesting that it's the length (front to back) of a cavity that is the primary determinant of cavity resonances. But I was pretty sure I'd also read a comment from him to the effect that measured results didn't match theory very well. (Which doesn't bode well for modelling.)
Anyway, I went back to the Linkwitz Lab site and, sure enough, found this page: https://www.linkwitzlab.com/models.htm#C
Siegfried said, there: "If you build an H baffle woofer ... there will also be a response peak due to a l/4 resonance of the waveguides in front and behind the drivers."
He then shows a nearfield response measurement of his Phoenix woofer baffle (a W-frame, actually) showing just such a peak:
He comments: "The PHOENIX woofer has D=19" (0.48 m) separation between its openings. The peak should be at f = 0.5*v/D = 357 Hz, but the cabinet layout is too complicated for such simple calculation to apply exactly."
This is what I read years ago. Going back to it, though, had me really scratching my head. The peak is nowhere near 357Hz, but also, I don't actually understand why SL said initially it's a l/4 resonance, (which is what you'd expect for a pipe open at one end) but then calculated the expected frequency as l/2.
So I was no further forward.
Recently, however, I stumbled across an old thread here on diyaudio which addresses the very question of cavity resonance:
https://www.diyaudio.com/community/threads/ripole-cavity-resonance-question.240193/
This got my hopes up. I was particularly pleased when saw that an answer to the question of how to calculate cavity resonance was offered by @bolserst. This is a key part of what he had to say:
"The cavity resonance is ... a Helmholtz type resonance which develops because the air inside the cavity acts like a spring and the air at the opening of the cavity acts like a mass. You can think of it as a vented or ported box with port length zero and port area the size of the opening. With this in mind, you can get an estimate of what the cavity resonance would be by using a calculator for a vented box. Just set the volume of the box equal to the volume of the cavity, and the area of the port equal to the area of the cavity opening. Then solve for the tuning frequency that gets you a port length of zero."
He also comments that quarter-wave theory only begins to apply when the cavity geometry is more pipe-like. It struck me immediately that this is a much more promising way of thinking about cavity resonances.
The next thing I realised was that there is an easy way for me to model them, because I'm familiar with how to model vented boxes in Basta! So, I fired up Basta! and had a go, and the results are very encouraging. The method I've settled on is actually not to model a cavity as a simple vented box. (Although you can if you like. However you'll get a rather 'busy' graph from that, with driver and vent responses, and a combined response that rolls off the low frequencies, but doesn't reflect the baffle dimensions.) A better way is actually to model a bandpass box with a single vent, and with the volume of the rear enclosure set very large. Like this: (NOTE: See post #14 below for my updated method.)
In this model, the driver behaviour is not constrained by the rear box volume, because Vb2 is set so large. The response curve you get is the response of the vent. You set Vb to your best estimate of the volume of the cavity, and then in the Vent/PR tab, you set the vent cross-sectional area to match the area you calculate for the cavity mouth. Then adjust the vent tuning frequency until the vent length is approximately zero.
I did this for the Phoenix woofer box (with a fair bit of guess-work) and got the response shown above. As you can see, it's not a bad match for Siegried's measured response. (There is actually a slight broadening of the resonance, because the Phoenix W-baffle dimensions generate slightly different resonances front and back. Siegfied's measurements show even more of a broadening in the resonance than my model did.) Note that the modelled response does not take account of the rear driver radiation, and therefore doesn't show the dipole roll-off at low frequencies. But Siegfried's measured response was near-field, so it doesn't show the dipole roll-off either. (You can model the dipole roll-off in Basta! by selecting "Baffle" as the enclosure type. You just can't model the roll-off and the cavity resonance at the same time.)
So, anyway, I'm extremely grateful to bolserst for getting me thinking more clearly about cavity resonances. And I can recommend Basta! as a simple way to generate a rough model. I'm hopeful it's reasonably accurate. When I get some time I'll do a few measurements of my own and see how well they match the modelling.
Hornresp can simulate H-Frame, U-Frame and Ripole loudspeakers taking enclosure "cavity" resonances into account.
Reactions: Abbiendi and Arez
Thanks David, yes, I've has a go at that. I couldn't see a way to play around with the geometry, though. For example the Linkwitz Phoenix has different cavities front and back. And I wanted to try modelling the likes of the XSD speaker which has small cavities at the front, and bigger ones created by wings at the back, or Perry Marshall's Bitches Brew, which is a U baffle of sorts, with slanted wings.
Siegfried Linkwitz put some of his analysis of H and U frame woofers here: https://www.linkwitzlab.com/frontiers.htm#L and here: https://www.linkwitzlab.com/H-U woofer2.htm His analysis is impressive, as his work so often was.
But if @bolserst is correct, and folded baffle cavity resonances can be modelled as Helmholz type resonances, SL appears to have missed that. No?
Of course, Basta! is just one of many programs/utilities that can model vented boxes - I happen to like it a lot for its ease of use. I'm going to play more with Hornresp, perhaps using the MLTL wizard, because (if I've got this right) it will model both pipe and Helmzolz behaviour.
OK, here's a quick attempt in Hornresp, using the input wizard, and modelling the front output of the Phoenix woofer unit as if it were an MLTL. The screenshot has both Basta and Hornresp models showing. In Hornresp, I'm showing Input 1, which is the front radiation.
(Note: if you compare the Hornresp prediction to SL's actual near-field measurement of the front output, in post #1 above, there's a remarkably good correlation above the main resonant peak - see the null around 500 Hz and the peaks above that. This is impressive!)
But if I show the Combined response, and use the Path Length feature to adjust for the effective baffle size, I should get a decent prediction of both the cavity behaviour and the dipole roll-off. Here you go:
Edit: I just realised I only entered one driver when doing the Hornresp model instead of a pair. That'll have thrown things off a little. Still, it looks like the method works pretty well.
...I'm extremely grateful to bolserst for getting me thinking more clearly about cavity resonances.
You are most welcome.
Looks like you are on the right track now with either Basta! or Hornresp. :up:
One additional comment I will add is that the effective mass at the opening of the cavity(ie the reactive part of the radiation impedance) is dependent on the radiation space the H-Baffle is radiating into. Hornresp allows you to set this so you can better model the cavity resonance. I'm not sure if Basta! has this ability, but I couldn't locate mention of it in the online user's guide.
Here is an example showing measurements for cavity resonance of H-frame measured 3 ways, vs the Hornresp predictions.
You can see that as the radiation space gets smaller the radiation impedance increases. This increases the effective mass and damping (ie lowers frequency and magnitude of cavity resonance)
Note that the response peak just above 1kHz is the first SLS12 cone break-up mode, so not anything to do with the cavity resonance.
More details on modeling of H-baffle with Hornresp here: https://www.diyaudio.com/community/threads/hornresp.119854/post-5923396
You may also find the U-frame modeling capability of interest: https://www.diyaudio.com/community/threads/hornresp.119854/post-6166811
Reactions: Abbiendi and ianbo
Is that the microphone (the black tube held down with blue tape) in the picture? If so, that is the wrong place to make the measurement if the pickup is near the baffle that the woofer is mounted to. The mic pickup should be located in the plane of the opening of the H-frame, or even a couple of inches farther out into the room (because there is an "end effect" just like with a port).
Reactions: Arez
I corrected the Hornresp model so it has a pair of drivers (in parallel) rather than a single driver. Here's the plot:
Output is up, impedance down - as you'd expect - but also the centre frequency of the resonance has moved up from about 208 Hz to 226 Hz, (which is much closer to the Basta! prediction).
Good eye! Yes, that is a LinearX M51 microphone that I often use for measuring inside of cavities and ports due to its small size. As long as frequency of interest has wavelength > 10x the length of the frame or port( or distance from port exit), the measured response is essentially identical. At high frequencies the measured pressure response will diverge. For an extreme example see post concerning response at the input and output of a 1.6m long port.
https://www.diyaudio.com/community/...tween-winisd-hornresponse.311268/post-5169553
The mic in the picture was being used to improve measurement fidelity at low frequencies by splicing together measurements near the cavity pressure boundary and in exit plane of cavity to remove as much as possible the contamination of the acoustic output of the other side of the dipole woofer. Even so, you can still notice the LF roll-off slope not quite matching the expected -12dB/oct roll-off.
No doubt you have attempted to measure response of front baffle mounted ports that get contaminated by the nearby woofer output. You can measure inside the port to improve the situation, but do need to be aware of the 10x rule for the upper frequency limit of valid data.
Reactions: ianbo
I noticed today that @LewinskiH01 has put measurements of his XSD style bass module up here: https://www.diyaudio.com/community/threads/the-xsd-speaker.385717/post-7904569
This gives me another opportunity to test how well my Basta! modelling might match measured response. So I entered the data for the drivers in LewinskiH01's build, the Dayton DC160-8 (which is not the original XSD woofer).
And I modelled twice. The first time I modelled the response for a pair of drivers in one of the XSD slots, treating the slot as a ported box and the mouth as a port with zero length (taking my best guess about the slot volume and mouth size). Secondly I modelled an octet of these drivers on an open baffle with the approximate dimensions of the XSD baffle. I reduced the source voltage to half of that used for the first model, to offset the 6dB increase because of the increased number of drivers. Here are the two SPL curves. Below 100 Hz the lower curve is the one to use, because it has the dipole roll-off. Above 100Hz you should pay attention to the upper curve, as it's the one that simulates the effects of the slots.
Now the measured response posted by @LewinskiH01 - this is measured without wings on the XSD-style bass module, and at 50cm. Basta! is modelling the far-field response, so you'd expect that the Basta! model would have a slightly steeper dipole roll-off.
Bearing all that in mind, I think the match is remarkably good.
One more update: I worked out a smarter way to use Basta! to model the measurement @LewinskiH01 did on his XSD style woofer unit (see post #13 above). This time I modelled it as a vented box, but I worked out how to get the front and rear radiation to combine better. Here's the plot I got:
Black is the combined front and rear response; dotted blue is the vent output (i.e. the front output from the slot); solid blue is the driver output (i.e. the rear output from the woofer module). Excursion and impedence are shown too. (Remember, I'm modelling just a pair of drivers, not the full octet.)
To get the front and rear to combine properly, to model the dipole roll-off, I unchecked the 'Far field response' box, set the measurement distance to 0.5m (which is what was used in the measurement), and positioned the mic on the vent axis. I set input power at 1.4V.
Now, this is where there's still a bit of a workaround involved. Basta thinks the drivers are mounted on the front baffle, whereas in the slot-loaded module they're effectively on the back. So, as a workaround, I positioned the drivers and the vent apart on the front baffle, to try to give a 'flight time' difference that might correspond to the dipole path distance between the front and rear radiation.
The sim is a very good match for the measurement, I'd say, at least up to 500-600 Hz.
One other point comes to mind. In NP's original Slot Loaded Open Baffle Project paper (see here: https://www.firstwatt.com/wp-content/uploads/2023/12/art_slob.pdf) Nelson suggested that with a slot area around a third of the cone area, slot-loading should give around a 9dB increase in the near field. Now, I'm estimating a vent area of around 85cm2, which is indeed about a third of the Sd of a pair of drivers. If you look at the curves for the front and rear output above, you'll see that the vent output is mostly about 8dB higher than the driver output - not a bad match.
Nelson also pointed out that this gain from slot-loading will diminish as you move further away - at his 3m listening distance it measured around 2.5dB, he said. Well, you can model this too, although not perfectly. If you increase the mic distance in Basta to 3m, this is what you get:
The two curves are much closer, as expected. In fact, the gap is only 1-2 dB through most of the bass range. That's a bit less than NP's measurements. Why? Probably because with a 3m mic distance, my workaround for the dipole roll-off is no longer working. The flight-time difference is now much less than the dipole source distance. The model is no longer going to be useful in the dipole-roll-off region.
You need to have another look - it is indeed possible 🙂.
@David McBean David, I've been looking at Hornresp again, to see if there is a way to model the addition of wings to an open baffle speaker. (See Perry Marshall's Bitches' Brew, for example: https://www.diyaudio.com/community/...ead-perry-marshalls-live-edge-dipoles.424917/) The wings create something like a U baffle, but neither the depth of the U nor the cross-section area are constant, so the OB models in Hornresp's input wizard won't apply, so far as I can see. Am I missing something?
A correction to my post #15 above. I realised that Basta! is not modelling any SPL gain from slot-loading - the higher SPL of the vent in the graph in post #14 is simply a result of the mic being much closer to the vent than to the drivers. Doh!
