Hi RsD:
Do you still have the 31.5 with the original CDM12? Mine has the CDMpro upgrade, with an EEPROM replacement. A part is removed (marked DF80, but I don't know what it is). A jumper cable is installed, allowing the ML card to fully control the transport. I actually wanted to downgrade to see if that was the servo reset fault.
DF80 is muRata EMIFIL DSSHi RsD:
The Cdm12ind of mark 31.5 is not the same as the software of Cdpro 31.5. Please change back to the original 29C010Hi RsD:
