Yup, first non dome tweeter I actually ever tried. I was not disappointed.Nice looking design Btw. Is that a HiVi tweeter?
Maybe it's easier than it looks, but I don't want to have to build a computer, and install software in order to buy an active crossover. These items are parts.A 4GB Raspberry Pi5 plus an 8-channel HiFiBerry Dac8x HAT is under $200... and DSP software is free.
I think you're confusing the term "active" with meaning that the amplifiers are in the box, which is not usually the case in Pro Audio (except for Meyer and PK brands). Most major PA brands (L-Acoustic, D&B, Clair) are actively powered by amplifiers that are not in the same enclosure as the drivers. I'm not taking about speakers on a stick. I'm talking about the elite Pro Audio speaker brands. All of them are fully active except one (D&B) that is a combination of active and passive. Sorry, but you clearly don't know the Pro Audio side and that's ok.Guy, nobody is going to lug around passive gear from show to show. Why would you?
The point is that there is a real reason that Pro Audio is almost exclusively active. The benefits are clear. Again, that doesn't mean that active is an excuse for a poor design. It also doesn't mean that everybody knows how to use DSP filters properly. You can still have the same problems as passive filters (running the woofers too high into their breakup modes, poor directivity, etc.). So it doesn't surprise me that there were bad sounding DSP speakers there.
I'm not defending the show. I wasn't there. I've heard terrible sounding active speakers. It's just as easy to mess that up as anything else which is what we're saying. Nobody is preaching. We just understand the technology and enjoy explaining it on this message board.Like I just said. Listen to them back to back at a show. Ya'll active guys are seriously tiring with your constant preaching, defending, hijacking, etc.
I'm calmer than you........You like active? Cool, just chill wayyyyyyyyyy out about it.
I was literally doing woodwork when I read this comment.One little comment and ya'll come out of the woodwork like evangelists defending their cult. Its really quite unnecessary.
The speakers frequency response might be decent, but I can't quite tell because you are using more than a 150dB wide scale with 10dB divisions. It is more common to plot the response with only about 40dB for the entire vertical axis. Can you do that?
Distortion is good above 500Hz, not as good below. You didn't mention what sort of SPL level you are using for playback during the distortion measurement, and this is important to know. If that is at 104dB at 1m then wow. If that is at 84dB at 1m then we are talking about something more normal for home hifi.
And let's not forget: off-axis measurements.
A speaker can be extremely linear on-axis (anechoic measurement) and still sound like crap when you put it in a room.
"Good, Fast, Cheap... pick two if you are lucky, sometimes you only get one"
In this case it means a DSP solution with (1) good performance and reliability (2) convenient to set up and use (3) inexpensive. If you are lucky you can get two of these.
In my case, I want high quality and high performance, and I want the convenience of a single self-contained chunk of hardware that does not involve a PC, operating systems, boot ups, and 6 or 8 cables running this way and that. This means I can not have it cheap... I need to spend some money. For me, the Hypex fusion plate amps are the best option.
Only you can determine what is best for you, but if you want to stay within a tight budget, you may need to be willing to deal with a computer/software based solution.
Maybe we need to stop the war between active and passive and just make a mix .
Has I understand we can reduce H3 using notch or series inductor. Like describe here but this page do not goes deep enough for me to understand exactly how it works with complete examples.
https://audiohorn.net/sciences/speaker-break-up/
And @abstract you seems to said the same here
On the other side @danville you seem to said that it is better with active because we can control cone breakup with active crossover due to less "resistance" (so literally the contrary).
Do both of you can explain more deeply the pros and cons they are seeing ? Does a D-amp with PFFB be the solution since they are not impacted by impedance fluctuation ?
All active filters; no passive components to shape the output impedance to be optimal across the different frequency ranges. That would be consistent with woofers becoming harsh near their break-up modes
1. Drivers are driven directly. This is easier for the amplifier and improves damping for the woofers (the amplifier provides a near short circuit for back EMF)
No, i belive they just chooses the easiest path 😉There is a reason that 95% of Pro Audio is active now hifi is moving towards that.
It's hard for me to tell what each unit does.The descriptions are sparse. I have amplifiers with analog rca inputs. I have AVRs with pre-amp inputs, and several 5-ch amplifiers of better quality. I would like it to be part of a HT, and music system at the same time, but not always.. Sometimes I set up a music only system in another room. For music, I use CDs. I don't stream. So, my HT uses a Roku with HDMI to an AVR. From there, I have pre-outs. What would I need to buy? Do I need a computer other than to download software? I have a W7 computer, but never allow it online. All online is using a Chromebook.@temp25 Ummm, that is really not much more than plugging that HAT onto the Pi and plugging the Pi into the wall. Sure, you have to install and use some software.
It's definitely way less work than assembling any analog electronics!
What would I need to buy to use pre-out from my AVR into the Rasberry, and then analog out to my amps?
Or analog out from the Rasberry into pre-amp in on an AVR.
Better yet, can I go straight from a BR player using digital, into the Rasberry?
After setup, does a computer need to be connected?
This is such a crucial point. It really is why so many speakers sound bad and it's why the full plethora of measurements are so important.And let's not forget: off-axis measurements.
Hahaha! Yeah............No, i belive they just chooses the easiest path 😉
@pefpef I don't think it's an "either this or that" thing, and my argument was general, not aimed at anyone's specific implementation.
In any case, my personal preference is for full-range speakers, where the requirement is for low SPL or nearfield listening, but let's say a decision has been made to go with a 3-way system. Then I completely agree that there are IMD advantages to splitting the frequency bands before they are amplified. However, I would also look at conservative use of passive filter components "as needed".
IME, tweeters that are padded down with resistors sound quite different from the exact same tweeters that are attenuated actively and run straight-through without any passive components in between them and the amplifier. For me, that was the seed that led me on a journey of discovery with damping factors / output impedance, etc.
If the source is already digital, then there's no (repeated) A2D conversion loss, so it seems almost a shame not to implement appropriate filters that complement any filters already done in analogue.
One neat trick that can be tried is a sliding damping factor, using just an air-cored choke as a passive low-pass filter for a woofer or mid-range, and active filters to add pre-emphasis. For instance, a passive 500Hz filter frequency could be combined with active correction for a net 2kHz cut-off.
You are 100% defending active speakers.I'm not defending the show. I wasn't there. I've heard terrible sounding active speakers. It's just as easy to mess that up as anything else which is what we're saying. Nobody is preaching. We just understand the technology and enjoy explaining it on this message board.
My favorite is when a new person pops in asking a simple question about a passive crossover and 3 active dudes pop in try to convince him to buy an $800 mini DSP. Then it spirals into some active speaker discussion and the one new guy is long gone.
The kii guy was trying to sell this as a benefit. Saying that the biggest advantage to his speakers was that they are so directive you can only hear them in a 10 degree window. Was the best selling of a design flaw I had ever heard.This is such a crucial point. It really is why so many speakers sound bad and it's why the full plethora of measurements are so important.
There seem to be several errors on that page which could lead to misunderstandings.Has I understand we can reduce H3 using notch or series inductor. Like describe here but this page do not goes deep enough for me to understand exactly how it works with complete examples.
It is dead clear you found the speakers you heard at the show using DSP didn't sound good, and since you know so little about DSP, you have decided that was the reason they sounded bad.I really cannot even guess as I know little about DSP designed speakers. I am very glad we went and listened to all of those designed as I have been considering going active for the last year or so. After that experience, I will be sticking to passives. I'm telling you though, it was dead clear which had dsp and which were passive.
I saw a youtube video last night of an AXPONA exhibitor explaining his "Fourier Transform" monstrosity of a loudspeaker system that is physically incapable to sound the same in more than one room position.
If I wasn't aware of the basic error made in the system design it would have been easy to blame the DSP, as most of those who heard it did.
Most questions about crossovers can't be answered simply.My favorite is when a new person pops in asking a simple question about a passive crossover and 3 active dudes pop in try to convince him to buy an $800 mini DSP. Then it spirals into some active speaker discussion and the one new guy is long gone.
That said, best to ignore anyone that would try to convince someone to use DSP in every situation.
Art
For me it´s complicated enough to build speakers & try to get good at it.You are 100% defending active speakers.
It incluedes knowlege about drivers, thier working volyme, damping, ultimate frequency of use, cone breakup etc.
And understand the simulationsprograms, bafflestep, radiation, nulls etc.
Then learn to build the cabinette and try to be good at that, inclueding everything that it entails.
And then to also adding a complicated technology like DSP doesn't sound healthy.
For sure a real competent person who is well versed in the DSP technology, have a real good chanse to "get the best" out of a not so good speaker, but you can put makeup on a pig to.
The industry of course wants us to buy more products (just like the pharmaceutical industry), but that doesn't mean that expensive products such as power purifiers, thick cables & other maby "snake oil products" make everything "better".
That was my experience. It will not be swayed by people saying "but but but... active is so much better". No, you've got the wrong person. To the three of us, the passive systems sounded better. They were more natural. And these are 3 people who go to live shows weekly. Sometimes multiple shows a week. And, if I am being told right, we are all listening to active systems every time we go. Yet, we all preferred the passive systems at the show. This was an experience, not something up for discussion. Please realize that. Knowledge about the technology does not change our experience.It is dead clear you found the speakers you heard at the show using DSP didn't sound good, and since you know so little about DSP, you have decided that was the reason they sounded bad.
Begs the next question: Do active systems require knowledge about how they work for them to sound good? Pretty sure you are trying to answer that with a resounding yes. I find that interesting.
New people do not know who to ignore and who to listen to. This situation happens even more on the PE forum. I am not active there but I do stalk and I see it a lot. The active guys popping into threads and making it a "but active is better" thread with almost no prompting is a sickness across the community as a whole.Most questions about crossovers can't be answered simply.
Summary:
*Goes to show and instead of talking purely about speakers they like and didn't like in a constructive manner - uses the context of the show to compare those speakers to their own superior talents and skills at building perfect speakers at home, and how professional companies could learn a lot from them because said companies largely don't know what they're doing and produce expensive rubbish.
* makes a dogmatic blanket statement completely bagging out DSP entirely, says all DSP speakers are objectively inferior.
*wonders why people politely offer an alternate viewpoint.
- My Experience at a HIFI Audio Convention - AXPONA 2025
