My Experience at a HIFI Audio Convention - AXPONA 2025
Nota bene that with the approach of DSP-izing passive multiways we talk about a delibarate and very rough use of DSP. If I would have to design a whole new system, I would hands down go DSP right from the beginning, starting by individually processing for every single driver. Actually even very fine multichannel DAC's got this ridiculously cheap, that there is no more excuse for not going DSP in search for a more advanced loudspeaker.
Agreed with your entire post. Wish more DIY folks saw it that way; it would help home multi-way catch up to proaudio.
comparing the passive crossover, which you know (have told me personally) has some weaknesses, to an optimized DSP crossover
Getting beyond acoustic issues is a robust first step since new issues have nowhere to hide.. then setting any crossover to manage each detail down to the limit of human hearing before comparisons. Talk of such significant audible differences usually speaks to one's experiences more than it does to the equipment.
Reactions: jawen
@temp25 Why the stipulation that a DSP has to be only $150?
Let's say you're designing a 2 way passive 2nd order crossover. If you're really good at VituixCad and measurements and simulation, MAYBE you'll get away with spending as little as $75 (total 4 inductors and at least 4 capacitors plus some resistors) - and that requires you to NAIL it the on the first take and we're assuming you don't have to to swap out any other differently valued parts to get it to sound right.
Odds are you will spend hours tinkering with the physical components, adding caps and resistors in parallel to get the values you're looking for. And fumble around figuring out you didn't wire it quite the way your schematic said.
I'm a pretty experienced speaker designer, and even with simulations I still have to tinker and substitute. It really requires a box of passive crossover parts of all different values. Which I have. But a box with a generous selection of passive parts costs many hundreds of dollars.
If you're building a 3 way with low crossover frequencies, the parts cost goes up 3-5X. The inductors in the Bitches Brews (which are mostly active DSP, partly passive) cost close to $100 each.
The DSP is infinitely adjustable, instantly adjustable, and fixed cost. I say a good user friendly DSP is easily worth the $250-500.
. I have about $500 worth of caps, and coils.
The center channel I just built is ruler flat, and I "nailed" the x-over pretty quick. The x-over would have cost me about $30, if I had to buy the parts. Music speakers take longer, but that's part of the fun.
If 3-ways were my thing, I'd probably be willing to spend $500 on DSP. I really don't like assembling, and soldering complicated x-overs.
At $150, I might buy one anyway, just to play with. I'm not buying a new PC if that's required, and I'm not going to build a DSP either.
This is true and an understatement. We all know that we change our crossovers several times and have a bunch of parts laying around. We also know that we spend much more on crossover parts than we want to admit. We have a bunch of parts on hand to get those components dialed exactly right. Some of us are obsessive so we have external crossovers to make the revisions easier.
Now, it's not just an obsessive habit. The reality is that passive components change so many factors that it is difficult to predict, even with good software. Putting passive components on woofers (especially inductors) can change the box alignment significantly. So, it takes a lot of trial and error to get it right. Plus, we are constantly getting better at measuring and objectively listening so we love to ge that extra 1-2db of compliance with our downward tilt off-axis and therefore bette run-room response.
Passive is much more expensive except when it's done with a proven design. Active gives us so many possibilities and advantages. There is a reason that 95% of Pro Audio is active now hifi is moving towards that.
Reactions: perrymarshall
That's why I was really hoping you could share the measurements of your speakers so we could correlate them to what sounds better than 90% of stuff at the show. Apologies if I missed the links somewhere in your nearly 1000 posts
This is it gated. At some point I plan to take everything I've made out to a field and put it on a very tall ladder so I can get full range measurements. Averaging a little over 0.6% distortion. Within 3db accuracy. Low end is all messed up because I took these at home in my very small Chicago living room.
Pretty decent I think
This is not true at all. What musicians and venue techs have you been talking to? Pro is all about power and all about coloring the music for a specific artist. This is simply easier to do when you can click a few buttons rather than have to swap out components inside of a speaker.
Let's also not forget that musician have to go to different venues. They have to carry the gear. Passives are heavy. Actives are easily to make changes when dealing with a new venue every night. Pro audio use case is so far and away different from home audio hifi. I am the only person I knew personally who has home hifi. Everyone else I know in this city that is into music utilizes pro hifi because it is their livelihood.
Reactions: ianbo
I am an international touring engineer.........I work for a band that does shows in stadiums. I could send you my resume if you want it........
Have you worked in Pro Audio? Pro is about even distribution throughout the venue. Sure, we color the sound to an extent but there is much more to it than clicking a few buttons. Which techs have you been talking to?
They don't carry the gear, but the trucks do. I've been touring for decades so I'm familiar with how it works.
Passives are heavy.
Active speakers, when they have the amplifiers in them, are heavier. Passive components don't add much weight to a Pro Audio speaker. The advantages are that the amplifiers are closer to the drivers and the passive components are not changing the alignment of the woofer in the box. Plus, actives are more efficient which is clearly important in Pro Audio. But it's much more than that. Actives gives us a better phase response and much better consistency.
We don't change the crossover settings (though there were a few line arrays in which we could many years ago). We change the EQ, which could be done just the same with passive speakers. D&B still utilizes passive components and a few other companies have them, but it's clear that active is the way to go for many reasons. This will also be the case in hifi once the designers are more savvy with it and the end user is willing to give up their amplifier choice. But there's no reason to make this the only way to go. I still love passive speakers and a good passive design is an excellent work of art.
But the physics of it is still the same. It's just a different room to operate in.
I work in Pro Audio and I make studio and home hifi speakers. But I guess we're probably not in the same city.
Guy, nobody is going to lug around passive gear from show to show. Why would you?
Like I just said. Listen to them back to back at a show. Ya'll active guys are seriously tiring with your constant preaching, defending, hijacking, etc.
You like active? Cool, just chill wayyyyyyyyyy out about it.
One little comment and ya'll come out of the woodwork like evangelists defending their cult. Its really quite unnecessary.
Reactions: ianbo
The speakers frequency response might be decent, but I can't quite tell because you are using more than a 150dB wide scale with 10dB divisions. It is more common to plot the response with only about 40dB for the entire vertical axis. Can you do that?
Distortion is good above 500Hz, not as good below. You didn't mention what sort of SPL level you are using for playback during the distortion measurement, and this is important to know. If that is at 104dB at 1m then wow. If that is at 84dB at 1m then we are talking about something more normal for home hifi.
Reactions: nfitch
DSP is plastic surgery for speakers.
Sort of, yes, a good plastic surgeon will do a fantastic job in restoring the functionality of skin and even of the deeper tissues, e.g. over a wide necrotic aera in the case of an unlucky paraplegic patient with a massive skin lesion. Plastic surgery will be a salvation for a hiker whose face has been ripped off by a grizzly also. Plastic surgery may help any patient with large skin tumors also. Plastic surgery is also a resort for people who have the urge to alter something about their natural look.
Plastic surgery offers wide possibilities. DSP also offers wide possibilities.
DSP offers all filtering options of a passive approach, and even more options not available with passive filtering. You like Bessell's? Then go DSP for a while and for fun! Because DSP e.g. offers the option of LTA (limited transfer aera) filters and at the same time mimicking Bessell transfer functions withing the passband. So in this example DSP joins the very best of two worlds. A smooth passband and a net cutoff for frequencies where a driver would eventually behave problematically. DSP, as mentionned before, can linearize phase independently of the frequency response. And, and, and ...
Beware: As with plastic surgery, also with DSP you may mess up a lot of things. But blaming DSP for mickey results is like blaming plastic surgeons for michael jackson's final look. If you did not like michale jackson's final look.
I am quite sure that most of the people cherishing the merits of passive systems while demonizing DSP at the same time have hardly had the opportunity to listen to a well designed (!!!) DSP setup.
Last not least: At AXPONA in every room you listen not only to a different speaker, but also to a different room. It begins with room geometry, with outfit, last not least with the numbers of people inside of the room, each person acting as a diffusor and reflector at the same time. So if you like to compare DSP vs. passive, then do it in normalized conditions.
I tried to hint about some blind spots, but I guess the nature of blind spots is that you can't see that you can't see that you can't see them.
Klippel has some interesting papers on distortion. Once you see the graphs of speaker impedance curves at mid-to-high frequencies, moving away from the 'nominal' value that we're all familiar with, and dynamically jumping around between min-max values in response to variables like cone displacement or current, it should begin to make sense that this is something that requires careful electronic design to support the speaker's requirements.
DSP only manipulates the input signal, and is unable to change some of the other characteristics imposed by passive filter components and the amplifiers themselves. If done well, those other characteristics can make a big difference to THD and IMD.
A listener walks into a room, is miles outside of the 'sweet spot', so the frequency flatness is bound to be sub-optimal anyway, but they are still able to discern whether HD is high or low.
Thanks! That would be great if you could do outside. It's also possible to do a gated measurement >300-500hz so its pretty accurate even indoors and then splice a nearfield below 300-500hz like JA/Stereophile. On axis and off axis of course. Maybe scaling 40db to 90db or so so like Erin does gives a pretty clear picture.
Nice looking design Btw. Is that a HiVi tweeter?
