Case study - THF51 SIT transistor acting as triode
Initially I received a schematic from one of our colleagues here, with a choke as load for the THF51 SIT transistor, capacitor coupled with the speaker. Since my trade is audio xfmrs I modified the schematic replacing the choke with an output transformer. I've added also an 1:3 input xfmr. Any comments are welcome! Thanks!
Reactions: Fuling
Nice design. It's good to see transformers and chokes. It should sound good.
I built a transformer coupled Tokin SIT amp: https://www.diyaudio.com/community/...ansformer-coupled-vfet-sit-amp-design.372261/. It's also a follower but with a transformer coupled SIT voltage amplifier as well. Output is about 18 watts into 8 ohms at 1% THD.
SITs do behave much like triodes and but unfortunately are becoming harder to find. Still, they are available and cheaper than high power tube triodes. Plus, they last much longer than tubes.
Reactions: Dorin Bodea
I don't see the point of this. A large, expensive, gapped for 3A transformer instead of a cap? Which apart from all other transfomer ills kills the damping factor?
The output impedance of a SIT follower is a bit marginal for normal speakers, i think the Df typically is about 15. The output transformer here cuts it at least by half, still good compared to a typical SET, but not great. The stepup input transformer is a similarly poor idea - SITs gates like being driven from a low impedance and here the driving impedance of the preamp is multiplied by 9 + dc resistance...
Not sure how much the triode characteristics benefit a follower anyway, perhaps not much.
It may be interesting to compare this to a common source topology where the transformer is in the drain and has a step down ratio. It may lose the novelty of being a spud though.
You'll want a buffer to drive the SIT gate properly at high frequency. Also, next time please quote the source of the curve data you showed in post #2.
Yes, I've noticed an attenuation above 12kHz, which dissapears if the input xfmr is 1:1 (it's all about playing with available impedances, where SIT has a lower input impedance than a native triode). The main reason I've inserted an input xfmr 1:3 there was for adapting the aprox. 2Vrms to what's needed to drive this device.
Also, I received the graph from one of our colleagues here, I don't know from where it is, but it is anyway more or less meaningless since the SIT acts as follower, as @analog_sa noticed 🙂
Then just use a good old garden type FET instead of wasting a SIT.
I knew what's on SS market maybe 30 years ago, but since then I've played with tubes exclusively. So feel free to suggest a list of actual SS devices in production today, which you consider less waste than a SIT... which was suggested to me on the initial schematic described at the beginning of this thread.
N. Pass is using SITs in his SIT-5 (common drain) amplifier. SITs have also been compared in common source and common drain configurations and have been preferred as followers by some people who prefer SITs over FETs.
This only to say some people with experience with them would not agree they are being wasted as followers.
