Need help designing a simple flip flop for 12V trigger
Joined 2014
See the attached circuit circled in red. The circuit senses a signal and provides -12V for on and +12V for off, just the opposite of ICEPower modules. I am wanting to have the circuit provide +12V for on and 0V for off. A little more complicated than a simple flip flop. Any ideas? I can build a simple circuit on a breadboard and piggyback off the +-15V to power it.
Thank you so much. I hadn't thought about just using a transistor, that makes sense. I was locked into a simple opamp. Pretty sure the load is insignificant. Class D amp I'm wanting to use shows a 47k resistor in series with the internal circuitry.
Got it figured out. I just adjust the 1k resistor to get the needed voltage on the input of the amp, of course, depending on the internal resistance on the input of the amp. Got it to 12.2V with the 47k in series to ground. I'll start with that and adjust as needed.
Reactions: rayma
What this is, is a feature board on a subwoofer. The SMPS power supply smoked and it is way to smoked to fix. So I am putting an ICEpower 300AS1 module in it, ran off the feature board. It will look stock from the outside.
