DIY EMI filter for power supply
Reactions: Mimiragon
Who knows, they probably mass produce million of them and can afford a lower price. But I wasn't talking about the capacitors, I was talking about the inductors. If they turn out to be working and of good quality it's a steal, you'd have inductors for a whole filter at a very affordable price.
There's only one way to find out.
Good coils are expensive! For line filters, I use vacuum-melted nanocrystalline coils with high permeability and very low Ri (internal resistance). The filtering effect of such coils is very consistent up to well over 100 kHz.
All my tubes amp heaters have AC and it is very bad, my tube pre has a line filter but the noise pass through.
Switch to DC heaters also because of wind/solar caused mains fluctuations. Give that tube pre a good regulated PSU. Despite all the often irrational objections of tube people against "sand" there is no other way anymore. The days of purely ohmic grid load are long gone, it is inverter heaven today. So it will be mains filtering, DC/regulated conversion and input filtering (against BT, Wireless, DECT, cell phone etc.) if one desires silence, possibly even SMPS for PSU in the near future.
BTW this post was typed with sand.
My SS is not affected, because the PS is class D and regulated and outside the amp, but a traditional diode, transformer etc especially the tube heaters suffer so much on certain days, I will have no choice to use a variac and a DC blocker, RFI filter combo.
Oh yes you do. Many transformer based PSUs will need replacement for SMPS with the current state/quality of mains voltage. Besides their many features a positive one is that these tolerate mains voltage fluctuations like a champ.
BTW you have a class D PSU!?
Chinese variation of 20 amps are cheap, so i could get one for the power amp and a small one 5 amps for the computer, dac, pre amp, phone,
I would have to first build a ac coupling with caps and power diodes, and before some rfi filter,
I could dial the proper ideal voltage for my amp and forget about bias and other inconveniences
It is in late night that the noise increases,
It is Saturday that the transformer buzz too much
