Can this phono preamp produce these measurements? They are more than good! But are they true?
Dual DC power supply from + 9 v to +18 v and - 9 v to -18 v, alternatively single power supply from +9 v to + 28 v DC (on customer request).
Input sensitivity 3 mv out 1470 mv gain 50 db, signal to noise ratio 105 db, impedance 47 Khom. frequency response 15 HZ 30 KHZ.
Reactions: lineup
I would believe that S/N with a shorted input and battery power supply. 50 dB (assuming at 1kHz) is a healthy gain for a MM phono pre. There is no way you'd ever get a 105 dB S/N unless the power supply was dead quite and the inputs were shorted.
Assuming that 105 dB means 105 dB RIAA- and A-weighted with respect to an input signal of 5 mV RMS, 1 kHz, which is the usual nominal level for MM phono amplifier signal-to-noise ratio measurements:
-105 dB with respect to 5 mV is 28.11706626 nV
Long ago, I calculated that the noise bandwidth of RIAA- and A-weighting is 3219 Hz with respect to the gain at 1 kHz.
28.11706626 nV/√(3219 Hz) ~= 495.5751442 pV/√Hz
The equivalent input noise voltage density of an NE5532 is 5 nV/√Hz, so about 20 dB higher.
There is no way you get more than about 85 dB RIAA- and A-weighted with an NE5532 even when the inputs are shorted, which renders the measurement useless anyway - unless they use an unusual reference signal level or measure the noise over a too narrow bandwidth.
Now I have this little mm/mc phono box project, what do you think could be improved a bit? I can start from here to do some practice, I only care about MM and that it does not exceed 100pf as my AT head requires. All the blue capacitors are 100 microfarad 25v
