Ricci's Skhorn Subwoofer
So from what i can see the B&C 21DS115 is one of the best drivers for the SKhorn, correct? (not including ipal). Is the 4ohm or 8ohm version better? wired in parallel or series. Sorry for the dumb question :/
want to build 2 of these in the summer (UK)
Post # 47 has simulated comparisons of various drivers:
18sw115-8, 21sw152-4, 21ds115-8, 18xl1800-8, 21Ipal-1.
Generally, the impedance does not make a driver better or worse, but may be more appropriate for the amplification chosen.
Hey Josh.
Amazing designs man! I've built a pair of th18s and they perform quite well but looking for the next project to sink my teeth into. Looks like 18" drivers will do pretty well in the skhorn but just wondering if the cab size will need to stay the same with 18 drivers?
Can anyone tell how much dB should expect from Skram and Skhorn over rcfTTS28a?
I was thinking about building few Skram subs with Ipal21 and ipal mod, but not sure if that would be sufficient upgrade since was expecting to halve the amount of boxes I usually use.
