Capacitor type and quality recommendations for RIAA preamp cartridge loading
Thank you for these measurements. It seems I need to revise my pre-conceptions about ceramic caps after modern improvements in technology - I would never have considered using them in a feedback loop but that last plot is impressive.
I'm currently browsing Digikey to order some and I will be able to compare them to the polystyrenes that I used on previous builds with the same design and pcb.
I built an entire preamp using mostly c0g and it sounds great. I wouldn’t use x5r or x7r in the audio path, but c0g/np0 is fine.
Reactions: SomeJoe
I’ve pretty much switched my whole pcb methodology when it comes to audio signals. I almost always exclusively use c0g/np0 unless I need 1uf or greater. Which thanks to the work of Tom and others here, I switch to the Nichicon Muse BP caps which they measured as essentially transparent in the THD department.
Here was the last vinyl RIAA/pre-amp I made for my amp. I tossed a wima on there just to spice up the visuals a bit, but the previous version just used c0g in its place and it sounded great. I never measured it, but it was based on the Elliot sound RIAA preamp, and it sounded way better than the commercial pre-amp it replaced.
Reactions: SomeJoe
While we're on the subject of ceramics....
Below is the tape loop amplifier of my vintage amp, which I upgraded with hi-fi opamp. I also designed a clone board with the schematic attached; PCBs are in the mail. On the picture the 22p compensation caps seem ceramic, but who knows which class - Information is scarce on this oldie.
I have them in my crosshairs for further upgrade but then reason kicks in and deem that useless, as part of a high pass filter with a corner frequency over 320 KHz the cap is basically out of the audible signal path. Is this a correct reasoning?
With the tape loop amp clone I could experiment with various cap types to see if there is audible difference, and as a baseline standard I'll put garden variety type I ceramics.
In this case I don't think the capacitance/voltage coefficient is an issue as the DC bias is negligible (consumer level signal), otherwise they wouldn't have designed it that way, right?
It's a common thing to use ceramic disks, identified as C0G or otherwise, in such a position. For example, the high gain phono stage with the c. -130dBc distortion level at 1kHz uses such circuitry in several locations, with typical roll offs in the 300kHz region.
Clearly at 1kHz the frequency ratio relative to 300khz is 300:1 or so, but what happens at 10kHz, for example, when the ratio is an order of magnitude lower?
Well, the answer, in this particular case, is that the distortion is c. 17dB worse at the same reference level of 6dBv and is almost entirely 2nd order. This is entirely consistent with the reduction in the feedback factor in the amplifier stages due to the increase in frequency and the increase in amplitude in the 46dB buffer due to the RIAA characteristic and there is no evidence that any secondary sources of distortion, say from the bandwidth limiting caps, comes into play.
Reactions: SomeJoe
About page 12 or so if I remember correctly.
There is also an extensive Audiokarma thread on the associated designs.
