Stacked opamps
Fun with op amps. I present, the "Bug". Stacking is nothing new but these stacked ne5532 op amps are playing very nicely with each other. Will have a vid with proper audio examples this week.
Tried that before...the dc offset make them run at huge idle currents which ask for heatsinks .They sound good as they run in pure class A, but they actually run at the upper limit of output dc current they can output and not sure how long will they last.
You get similar sound if you naturally idle them at 2...5 mA instead of paralleling them the wrong way at 40 mA each.
Clearly the wrong way to go.
With caps and resistors this is running cool. with no resistors the outputs will have a battle royal.
"The soldered stack presents a wonderful opportunity to surreptitiously introduce a placebo into the listening tests."
Best word salad to date! Excellent way to introduce verbose, unverified, biased and even apparently prescient predictions of pompous presumptions.
Reactions: analog_sa
Not my invention. Just running with it and so far, great results. Greg has great vids on his Virtual HiFi YouTube channel.
Those paralleled opamps from company Virtual HiFi are running very hot, they know what to charge for their products though. :)
Below link to my earlier post there's an IR picture attached showing how hot those are running with the heatsinks on.
ps. the whole post is not visible, so go to the actual post to view full content.
Well...so far zero heat issues and sounds great. He is smart to have heatsinks for enclosed cases. Yup, saw all his info and even his warnings. After I post actual samples, if people hate it fine, in the meantime I will simply ignore anymore folks that don't actually want a discussion.
Is there anything you would like to discuss?
Yes, now we are talking. This is why Greg from virtual HiFi also pursued this. I did a vid on how a Sparkos op amp swap worked, and it worked extremely well. Not the same thing at all, but for the folks that can't hear the difference between op amps, I recommend a critical listening class or a hearing aid. Not directed at you, just the folks that judge without listening or have zero ability to discern differences.
@jazzboy sure keep on with your project, could you perhaps measure the voltage over those 100R's output resistors at standby, ie no input signal, that would show how much DC offsets there is.
As for Virtual HiFi I have no idea what they are doing to make the opamps draw so much current, but guessing they loaded the output so the opamps run in Class A.
FWIW in the Yamaha TX950 they paralleled the two halves of an NJM 2068 dual opamp. They did it to lower the noise. I suspennt there are other chips with low enough offset and close enugh match to get away with this. They would most likely be recent chips on new processes where everything is a much closer match.
Will do next swap. I am using the same value resistors as in his photos and from reading, the .1 micro arrad was chosen. So not sure the heat. But!!!!! I am using the setup in a phono pre.
The resistors are used as buffers between the outputs of the op amps. Tons of info on doing that.
