Review of LaVoce SAN184.50
Depends on how it is sewn and conducted. If it is just in the top spider and not sewn too deeply, that looks fine, and also generous "wave" of the lead especially near the tripple joint makes it look very good with very little bending at excursion. But indeed in case of breaking, the sewn ones still will be a nightmare compared to normal ones.
I made this model for another thread.
is this a TL or a TH, asking cause on most of the TH designs you see expanding areas, hence the Horn name,
BP1 drawing do not have any expanding CSA
all bends are 90 degree angles.
i roughy modified with MS paint his sketch to add the expansion CSA
this is a "nornal' TH
any sim differences between one and the other ?
better efficiency ?
or just easier to build as there are no angles
Reactions: Crashpc
I was thinking that too, and there are some data on TL being basically same or less efficient in the eyes of Hoffman's iron law. I am all for getting most performance from the driver, but it must be steady performance not just peak sim, and it must make sense. I already do not like few things about the speaker being crammed into such space with such CSA, and any try that fails just gets insanely costly. But hey, I can easily postpone it and try in a month or two.
Is the ‘1/4 wave resonator’ more or less efficient with the driver in the mouth or exposed as a ‘direct radiator’ ?
In many of @BP1Fanatic designs he covers the driver with a small crossectional area vent exit (the continued shape of his tapered pipes) and if I do that to any of my existing designs (where the vent is right next to the driver, but not covering it) it is quite obviously not as ‘loud’ , but maybe a bit of a filter?
View attachment 1418421 this is a "normal' TH
better efficiency ?
Stepped TH.
Technically, it's a positive flare TH since the CSA goes from 18.25" x 5" throat to 18.25" x 8" mouth.
TL = constant expansion = sims in HR as a round pipe whereas a TH is expanding even if just a two step pipe and if the expanded pipe is at the closed end = inverse TH or often (mis) labeled as a TQWT.
Negative flare TH = Tapered-Tapped Quarter Wave Tube or Pipe (T-TQWT or T-TQWP).
Straight flare TH = Tapped Quarter Wave Tube or Pipe (TQWT or TQWP).
Reactions: GM
Hofmann's Iron Law...efficient, low, small...pick 2.
Positive flare TH = efficient & big.
Negative flare TH = low & small.
Straight flare TH = ease of build, no angles.
A stepped TH eliminates the angles, but Hofmann's Iron Law still applies.
Step up = efficient & big.
Step down = low & small.
Remember, a TH in it's simplest form (single fold) is only 7 boards just like a BR enclosure.
I notice a stepped tapped pipe/horn has a big dead zone surrounding ~Fb x 4 (like all folded TL with driver @ vent) which might help with a crossover ? (Full wavelength, coming out the vent to the other side of the driver out of phase.)
Simple half and half split of the CSA in a single fold pipe (or similar)
If you do it with a horn flare that will create all kinds of crazy stuff up top and fill in the dead zone that otherwise was half silent conveniently
It's about using the right driver specs (vented chart same for TL/horn):
~0.403, Vb = Vas, Fb = Fs [MLTL]
< ~0.403, Vb = < Vas, Fb = > Fs [inverse tapered MLTQWT]
~0.403, Vb = > Vas, Fb = < Fs [expanding taper MLTQWT/MLhorn]
(Qts'): (Qts) + any added series resistance (Rs)
