How to know if a sub driver would work with a specific sub design?
Hello everyone I would like to build an OTHORN subwoofer and I saw that the Beyma 18SW1600ND was one of the compatible drivers. Well those drivers are no longer in production, But Beyma tells me they have a substitute that should work, the 18LEX1600ND.
Now my question is how could I tell if this drive is really compatible with the OTHORN sub design? Any help or suggestion will be greatly appreciated.
Look for the thread on that design and substitute the TS parameters in the horn response info shared to take a peek. It’s really intersting to compare and. Contrast things and observe how the damping/suspension stiffness (and motorforce) can make or break some of those ‘high compression’ horn shaped resonators
Reactions: darklight
Hello everyone I would build like to build a OTHORN subwoofer and I saw that the Beyma 18SW1600ND was one of the compatible drives. Well those drives are no longer in production, but Beyma tells me they have a substitute that should work, the 18LEX1600ND.
Greets!
Good question! During a tour of Altec's plant in '68 I asked what all did they test for and told +/- 10 % reference efficiency (eff/n0), which seemed kind of interesting since I knew their published Fs specs were often way off even after prosound apps break-in!
Fast forward several years and learning a bunch more speaker design theory and it became obvious: Thiele Small parameters equations – How each one affects the others
n0 is a percentage, showing how efficient the driver is at converting an electrical signal to an acoustical one. As a result, the bigger the number, the greater the reference sound pressure level.
n0 = (9.7822 * 10-10 * Vas * Fs3) / Qes
  • n0 above is a ratio, not a percentage. To make it a percentage multiply by 100.
  • Vas is in liters.
  • Fs in Hz.
In short, Beyma is using a bit higher percentage, but Altec at the time was known for promoting/being 'best', so compare them in Hornresp or similar and you tell us what percentage is acceptable. 😉
Reactions: BP1Fanatic
How do i make use of all info that he posted in that original thread? Also most of what I saw there was script for akabak. and and few screen shots of hornresp.
Seems it will excite the resonances in the ‘horn’ but is a bit reluctant to do much of the work in between?
Motor force issue or its inability to play the lowest frequencies (Fb of 30hz) in such a small initial crossectional area ? (It bulges up near 40 hz instead)
*Just observing, I’m not sure exactly how this works *
