Would something like this be useful to you, or is it just antiquated today? (I'm not affiliated with the seller)
https://www.usaudiomart.com/details/649280351-bruel-amp-kjar-audio-test-amp-measurement/
OMG, do it with a PC and some software ! BTW that B&K is over 50 years old.......
As suggested by Netlist, I have tried Scott Wurcer's tool.. works well. it's specifically developed to test phono cartridges.
The output is very very low. But may need some certification. Need to check on this.so do cartridges have individual EM susceptibility testing?
There may be stylus quality standards too, thinking about it.
Thanks for your inputs.
Can you give me a link to that please ? For quick stuff I use https://www.audiotester.de/ and the Clearaudio Test Record.Scott Wurcer's tool
Does the manufacturer of your "new" cartridge not have measurement facilities ?
It provides frequency response, crosstalk, 2 & 3 order harmonics.
I have Ultimate Analog Test record. Looking for CBS STR100.
Does Clear Audio has single track with 20-20kz sweep?
Yes, have look here:Does Clear Audio has single track with 20-20kz sweep?
https://www.technologyfactory.eu/en...audio-ca-trs-1007-test-record/a-3966-10000142
Hello, perhaps you can try the 1 kHz to 20 kHz -20 dB sweep track (side A, track 6). It should give more than nothing.I have Ultimate Analog Test record. Looking for CBS STR100.
This cartridge is made by self and want to take it ahead hence posted on this forum and must say, got lot of good inputs and suggestions.
Would like to thank each one of you and in particular to Netlist.
Yes. Have used track 6 and 7.. it does provide the required views but the amplitude varies and not very convenient for display if we have to combine 6 & 7 track output. Individually 6 & 7 work great.Hello, perhaps you can try the 1 kHz to 20 kHz -20 dB sweep track (side A, track 6). It should give more than nothing.
slightly OT, but since it was mentioned here:
Are there any more informations regarding this SJplot Python script by Scott Wurcer ... for example a kind of manual how to use it, or further links?
jauu
Calvin
jauu
Calvin
for someone unfamiliar with python etc. ...
if it were, than I would not have asked ... obviously. 🙄
- Analogue Source
- New Moving Coil Cartridge
