Impedance graph-How concerned should I be about a 2 ohm load?
This is an impedance graph of my DIY 3 way build.
Two Satori WO24P (8 ohm nominal) woofers in parallel
One Scanspeak 18M 4531 Mid Range
One Wavecore TW030WA11 Tweeter
The final Crossover is all 2nd order stuff. But the impedance graph is a bit concerning. I use Class D Ncore and Purifi amplifiers which are rated for 2 ohms. The load dips to 2 ohms between 200 and 300Hz. It also dips to 2.4 ohms between 75 and 200Hz. Otherwise it looks clean. How concerned should I be?
While the amps can probably handle the load without issue, the more salient point is typically whether the crossover is worsening the load unnecessarily. Comparing the raw impedance of the woofers in parallel (with no crossover or other drivers connected in the model) to that of the final impedance of your design may help point out areas that might deserve some attention.
As an amplifier designer type guy, my concern with your impedance plot is the 2 ohm region is very wide and flat right in the region where there is a lot of music energy ie 70 Hz through to 300 or 400 Hz. If I’m reading the graph correctly the phase angle is about -45 deg through to 0 deg over that region, so luckily not too bad. If you could get the minimum Z above 3 ohms (3.5 would bd great), I’d say that would be better.
Both brands have a wide range of power, and current limiting at 2 ohms.
There would be a difference between running a 2000 watt amp at 200 watts and a 200 watt amp at 200 watts.
That said, as long as the amp is not running hot, I would not be concerned running an amp rated for two ohms at two ohms between 75 and 300 Hz where dynamic range would generally result in less than 10% of peak power used.
Reactions: ThatSoundsGood
Would you show the woofer and mid responses with and without the crossover, and the crossover itself..
OK. Here's your answers. Have at it.
Notes: These are near-field measurements. The woofers are a measurement of one woofer but there are 2. I apologize for the crude diagram of the crossover but I don't use any simulation software so I just threw it together. Woofers are a simple 2nd order. Mid is 2nd order high pass, baffle step circuit then 2nd order low pass.
  • Avalanche Cross.pdf
    Avalanche Cross.pdf
Yeah, do you have any suggestions on how to do that without a massacre to my frequency response (which is really good t this point).
See my other post that has this graph and let me know what you think. Thanks to you and everyone for the help and insight on this.
Reactions: mattstat
Also, keep in mind here:
I'm trying to cross the mis as low as possible to the woofers because the center to center spacing between woofers and mid range is 22.5". I put both woofers at the floor to keep the floor bounce to a minimum.
C2 is after the L3 (closer to the driver)
OK, that's where it should be. I just wasn't sure where you had it given what was in your PDF.
Your midrange circuit seems to be pulling impedance down around 200 Hz. That can likely be improved.
Stating where your cross points were intended to be and how much baffle step compensation you were aiming for may help those who want to model it for you.
