Not dave, but I have TC9 and CHN50 at home. The CHN50 is the better driver by much IMO and sounds much more accurate and pleasing in the long run.
10cm and bass works only for desktop loudspeakers in close listening or corner placement.
If you take a 15cm driver close to a back wall I got a fullrange which measures like this
@perrymarshall
Usually you have to build ready developed loudspeakers from DIY loudspeaker magazines if you have no measurement equipment.
If you try without assistance (no magazines, no measurement system, no listening experience, no knowledge how to do it) the way is stoney to make a good loudspeaker and usually most commercial designs will sound better.
But with experience and time you learn to do things which you cannot buy anywhere.
For example a simple 15cm fullrange driver which in a 29 liter reflex box made perfect sound, no crossover at all it goes up to 12khz...
NO ! I don't need it . (the room is 4,7 x 6,4 m).Are you using subwoofer?
The "short side" amplifies the lows and I have sensitive ears (and not very many furniture). At this moment I'm listening this and it is very pleasant.
Elias
https://www.toutlehautparleur.com/haut-parleur.html
you can find what you are seeking for
Elias
P.S. My best suggestion is that . I have it and like it very much (without many compromises)
I think I am among the rare ones who did not like the TC9. I bought it because many people praised it...
Yes, it is still cheap enogh, sounds nice and smooth at first.
But after I while I noticed that some details in the music get lost, like in a fog, and the overall impression begins to fade. Some generic 3" JVC ones sound better.
I have not heard other small fullrangers, woul like te hear Faital 3Fe22 and/or CHN50P...
Just my
Just my
Personally I'd like to hear these:
https://www.toutlehautparleur.com/p...de-markaudio-chn-50p-mica-4-ohm-102-9-mm.html
My top favorite best bang for your buck 3” full range driver is The CHN -50’s by far. Price and performance in sound and built quality. I have the 50p version but, Will make a speaker next spring 2025. The light blue cones were the first generation of Mark Audios paper cones like the Alpair 6p’s so had and sold to a friend. The black cones must be the second generation and the newer white cones must be the 3rd and newest generation of cones. I wonder what the difference is in this new cone? Enjoy The drivers. JeffBest price/performance: CHR/CHP-50 certainlky would be serious candidates.
dave
I just see silver CHN-50 alloy cone drivers, and the CHN-50p Mica drivers on the main website.The black cones must be the second generation and the newer white cones must be the 3rd and newest generation of cones. I wonder what the difference is in this new cone?
jeff
Anyone seen / got measurements of the SB10PGC21–4
I’m interesting in >400Hz performance only as in WAW
TC9 is not cheap anymore, I think, that us, DIY crowd, kinda spoiled it. Luckily there are more than this one in the wild. The sad part is that as our common stuff is transitioning from petrol to electric - all copper, neodymium and other electric motor building stuff gets more expensive. Extra 5 EUR for simple driver is a lot, but 10 EUR for 10+ inch driver is not much.
Luckily there are many drivers which are comparable to TC9 in 20 EUR range. I even like Visaton FRS 8 more, which is cheaper right now.
Even when it was cheap the TC9 wasn’t worth the entry cost.
For a budget 3” driver, i recommend the Markaudio CHN-50.
dave
dave
I never tried the TC9 speakers but the Vifa TG9-FD10/04 drivers were nice but, not the cats meow as alot of diyer’s enjoyed them. The Mark Audios CHN -50’s are a better all around driver. Not good in this area or that area just a good all around best bang for your buck drivers. That’s why they are my favorite 3” inch full range driver.I think I am among the rare ones who did not like the TC9. I bought it because many people praised it...
Just myI didn’t like the TC9 as well.
Is there tin foil on this driver?10cm and bass works only for desktop loudspeakers in close listening or corner placement.
@perrymarshall
yes, I do this frequently and described it for everyone how to DIY:
just read from post one of the thread
Constrained Layer damping:
A hint I got here from the forum as a key to good sound from sandwich structure.
Now used silicone sealant for applying aluminium foil to the paper cone.
Finger snipping test shows enhanced damping due to the properties of the silicone.
Work goes faster than with the household glue I used usually.
That one is a decent driver. Much better than its sibling.
dave
- Full Range
- 2.5 to 4 inch best price quality ratio
