Noise measurements for LiFePo4 and supercapacitors?
Here's the Jung SR Positive reg, y-axis is "Ohms"
Hello,
What are we waiting from a good power supply for audio ?
I assume, filtering from the main, low impedancewith flatish waide bandwith, low inductance.
What are the poor and cons of such super cells VS super caps ? What I see is a lythic is better ESR and Tang loss than Super caps. Batteries A123 LIFEPO didn't convinced me on a Masterclok.
Nowadays it seems people like Farad supercells to filter the main and the reg before are just to charge them and permit isolation from the main and near constant DC, so reduced ground loop (the loop is between the load and te cap, not the power traffo starground)
Do I understand correctly ?
It is difficult to see what is good enough for audio among the Super ref à la WJ, The super cells double layer caps (100 mHonks at best), the Super cells (inductancee ? bigger ground loop ?).
Here Thorsten Loesch propposed a constant super caps bank for a dac, Farad are huge so serie connection to acheive the good voltage needed is feasible but what about the ESR at the end. Of course I surmise the quality of the main and EMC is totally rulled with such layout ! But does it sstill work if one put a lower tang/loss or lower ESR cap after the bank between the load ?
Me I have stil 3 A123 cells that doersn't serve after few experiments !
why you think you dont like the A123?
  • Does a supercap improve things? or a electrolhytic capacitor bank in between? which should improve "source" ESR
  • is it the non constant voltage ?
  • noise shouldnt be a concen here or? (tho i havent tried/measured ian canadas battery supplys)
is there really much else to it?
I have a GainWire preamplifier and I thought that it would be powered by LiFePO4 batteries (26650 A123), 2pcs (+/- 16V) 5s1p (5 series A123).
I would also like to reduce the output resistance so I would install 10-10 more 680uF high current low ESR capacitors ( Panasonic EEH-AZSV681UB) in the output.
Anyone has experience with battery powering a preamp?
I have more Salas UBiB 1.3 PSU, but I don't which is better?
Thank you
@topicreader : Hi .. I will take the liberty to just briefly give you a partial reply to your question - as well as I can ...
  • As I mentioned earlier using Lithium batteries in series requires some kind of balancing so that the batteries charge, and continue to charge, to identical voltages. In my experience (based on Li-ion batteries, appr. 2000 mAH capacity) the imbalancing current is not higher than ~5 mA so the batteries do not imbalance with very high currents. If a resistor balancing is used I personally would use an appr. 1k resistor across a Li-ion battery of 2000 mAH capacity.
  • If the batteries are not constantly float charged when used for playback I have observed that they tend to lose some dynamics if the discharge current gets beyond some level. Personally, I would not discharge a 2000 mAH battery with a higher current than, say, 50 mA. If higher discharge currents are needed the cells may be paralleled or a higher battery capacity may be used.
  • Regarding a comparison of merits between Salas' PSU and batteries I cannot reply to this as I have never used this regulator. However, in my general experience I have never heard a wall-supplied PSU provide the space, overview, silence, instrument definition, and overall "surplus" that batteries (used feasibly) may provide.
I hope this helps,
Jesper
Hi again,
In hindsight I would like to add a follow-up to my post above i.e. #132.
Thinking about it I personally would not use a passive balancing circuitry as I consider a high level of safety desirable/necessary particularly with Li-ion batteries. Thus a suitably dimensioned active balancing circuitry would be my choice.
Cheers, Jesper
arent we talking about noise?
With shunt regulators like Salas' UBiB, we have only 420 nV total noise in the 20Hz-20Khz bandwidth. Measured, no simulation phantasy involved.
https://www.diyaudio.com/community/...-ultrabib-shunt-regulator.322411/post-7391190
With Jung-Didden super-regulator and adequate opamp choice, we have just a little more.
https://www.diyaudio.com/community/threads/super-regulator.247281/post-7263619
There aren’t many audio applications, voltage references excluded, where those noise level are not adequate.
no doubt, 420nV is impressive, much more than adequate (for most people), and possibly very close to the technological limit
but clearly we are looking for the best at our disposal, i have yet to see guys working with low noise amplifiers used super regs for their tasks instead of batteries, any?!
I have powered Groner's 400pV/RtHz amplifier from Linear Audio with alkalines, super-reg and silent switcher and the baseline noise remains unchanged. With the Pearl 2, same result (Pearl 2 uses 24V regulators which I disabled).
With short leads the "mains hump" largely disappears with batteries.
