Powering a Microcontroller from Nelson Pass PSU
Joined 2024
Hello,
I built the F5m amp with Nelson Pass PSU. I would like to add a small microcontroller inside the chassis to allow me to control the front panel LED(s). My board would draw under 200mA and the voltage regulator input has a max of 36V.
The Nelson Pass has +-24V rails fed from the transformer sourced diode rectifier bridges(2). Can I tap into the GND and +24V rail on the PSU board to supply my microcontroller voltage regulator or will that potentially cause a negative side effects on the F5m circuit/audio? My board would power a couple of LEDs at 20mA each or so and it will be using PWM so I don't want that interfering with the audio.
Thank you
If I connect the channel outputs to 2 channels on my oScope, do I risk blowing or damaging the amp? I could send a clean wave and see if it's clean maybe? Not sure my ears are sensitive enough to detect noise. ( age son )
I'm thinking the large caps and filter resistors on the PSU will already be smoothing out noise so I could just tap in to the +24V without bothering the audio power. It should be ok but I'm still learning about audio and thought I could confirm this with an expert.
I use my REW/Focusrite FFT rig to check noise.
For ultrasonic noise an oscilloscope may be better.
To check the amplifier output you should have a load (8R high wattage resistor) attached to the output.
Be sure that the oscilloscope ground is connected the Ground on the amplifier.
There is probably more danger to the oscilloscope than to the amplifier.
  • Thank You
Reactions: roboDNA
I'm not sure. Has anyone else used a microcontroller in an amp project? If so, I'm curious to find out what was used as its power source. ( tap into the main transformer, or add a second transformer? )
I have designed many audio projects with PIC microcontrollers in them.
I usually drop the voltage using 5W zeners and then into a 5 volt regulator.
Never had a problem with interference.
I'll drop the +24V down using a 12V 5W zener in serial with no resistor as you suggest. I currently use VXO7803-500-M as a voltage regulator with +12V in ( for Eurorack ) and it does not run hot at all I don't think. I must be drawing much less than 200mA.
I have not tapped off the amp power supply for a microprocessor, but I have powered a low voltage cooling fan. I was not able to get rid of all the added noise, which showed up as 40 Hz and its harmonics.
In the end, I just lived with it. I didn't really notice it, and I didn't want to add a separate power supply.
