I am a beginner and i need help with my speaker build
So i will give now the photo and information of the build
For the box of the speaker i have found a guy that gave it to me for free.
As for the speakers I have chosen
Subwoofer : Dayton audio epique E180He-44(does 4+4 mean 8ohm?)
Midrange: Markaudio maop 11
Tweeter : Skar audio VX4-ST super tweeter 4 ohm ( I wanted to buy from kleinanzeigen a scan speak 2905 tweeter but it is sold)
For the amp i chosen Wondom jab5 4×100W
And a battery board that need to be change because it can not supply enought amps to the amp board
And i want to build the crossover myself so i can learn something new and useful
PDF from amp board and battery board
I am open to design changes since I think that I have made a lot of mistakes
You may try this one! opps... opposite of 1.8mH the cap value is 3.3uF 🙂
note: use all cap min 100V, 2.2/3.3/4.7 are quite reasonable price but 15/33 may be quite a bit expensive but you may use two electrolytic capacitor in serise in this manner ---| (---) |---- [33 + 33 uf = 16.5 uf]
Maybe it's better to put the work In the passive filters for the Maop 11 and the Skar tweeter. Since there are 2 amplifiers per channel, the crossover frequency can be kept rather low (200-300 Hz?) ...
I dunno, the dual voice coil suggests to use all the 4 channels for the woofers!!!
You mean that I should connect al the 8 cables to the subwoofer since the amp board can 4 ch 100w , 3 ch 1×200w 2×100w or 2 ch 2×200w
I don't know your attitude towards this build. If it needs batteries, then it's gotta be mobile or... private grid!!
So, if mobile and less power hungry, try 2 channels splitted woofer( series connected) and midwoofer+twetter passive crossed.
Or the power subwoofer system that uses 2 more amplifiers for the midwoofer and tweeter.
