There have been endless discussions about 2SK170BL replacement.
I have already published data indicating that 2x209GR in parallel would be a good replacement in all respects.
https://www.diyaudio.com/forums/pas...source-follower-applications.html#post5582425
Of course you can also use a single 2SK2145GR, which is in principle 2x 2SK209GR.
They are not guarantee to be a match pair, and from experience some 10% are poorly matched.
So the best is to measure the Idss of each JFET and select only the good ones.
But for those who just want to save money and don't care about performance,
no one will stop you from using the 2SK2145GR without any selection.
Here are the Gerber files of a small 5x5mm conversion PCB.
Both size and pin assignment correspond to the 2SK170BL.
Plenty avaiable at Mouser, etc.
What more do you want ....
Patrick
Patrick
Very nice. Thanks. Is it much effort to create a 20 x 20 pcs 100mm x 100mm panel? This is a standard size for JLCPCB. I would be willing to place and order and distribute some in the USA.
I would be interested in a panel of these. Keep us posted on a GB woofertester, if that becomes a reality. Thanks Patrick!
1) You can ask the PCB shop to panelise for you.
2) I'll let you find out how much MORE they charge you for having multiple PCBs in one panel.
3) You can submit a 5mm x 5mm PCB and ask for 30 or 50 pcs and see how much they cost compared to 10.
4) You can also compare the PCB plus postage to US inland post.
I post the Gerbers for your own DIY use.
I don't think anyone will need 2000~4000 a time.
Patrick
Patrick
Patrick
I was offering to manage a group buy. I have very limited PCB design experience. That said, I looked at tools for panelization and there may be something open source that could do it.
My thoughts about your little PCB began when I first read Zen Mod's usage of the 2SK2145. I looked into adapter PCBs but did not find anything I liked.
Way back then, I purchased two different clamshell fixtures for SOT pars. So, I have the capability to perform curve tracing and matching of the 2SK2145 parts.
As to usage, I think lifting a couple of legs of the 2SK2145BL and using them as a single would be helpful for some DIY projects. Also paralleling the halves of the GR part would be useful.
Thanks again for sharing your designs. I have more than one of your designs in the pipeline for a build (J2 clone, ACP+ bipolar). Waiting on semis for both.
cheers
Many "low-cost" PCB shops will refuse to do 20x20 panels.
This is not prototyping quantities.
You have been warned.
Patrick
Patrick
Patrick
Understood and thank you.
I read through the fine print at JLCPCB. They state that if your 100mm x 100mm board is an array of identical PCBs, they will not charge extra.
We shall see. At the moment, I am trying out a panelizer program and have not had any success as of yet.
Did this die in silence??
Did anyone ever come up wth a "panel"/gerbers of 100mm x 100mm or 100mm x 160mm of the one from post #1 ??
Or buy them from eBay :
Patrick
Thanks Patrick....Or buy them from eBay :
Do you have a link??
My Ebay search returns nothing :-(
I did..... Only showed sensors and like stuff.You can do image search with Google using the above picture.
Never mind... found link in another thread.
Thanks anyway 👍
Well...... Impressed as I was with these
in the Pearl-3, they were a bit too expensive for my taste, so I finally pulled myself together and went onto
the JLCPCB-site with the gerbers, generously provided by Patrick. Little confusing at first, but finally
managed to do the panelling (I hope) on the order site. I ordered 5 pcs. of 90 x 150mm panels,
so will probably have some surplus for costprice, when they arrive. Will probably be 2 or 3 pieces for a $.
Anyone interrested can shoot me a PM.
My solution for using the 2SK2145 was to buy cheap SOT23-6 adapter boards, which I found on eBay with 0.4" spacing. Then I found some suitable IC sockets to use for matching parts on a test board. The cheapest one of those I found is this 22 pos from DK. (You may get lucky and find an adapter board with the more standard 0.3" spacing, which would make the socket choice easier.)
Once tested, you can solder the (T/H) header pins for the selected part directly to the board you're making. You just need the one socket for the test board, unless you prefer to socket the parts on your project board too.
- Adaptor PCB 2SK2145GR as 2SK170BL Substitute
