The Minimum, to Use Opamp as Input in Power Amp
What’s the minimum requirement to use opamp as the input stage of the power amplifier? It might be:
1, Good voltage swing, as the power rail voltage is often limited.
2, A bias network that could provide a fixed voltage for the output stage.
Here we go.
The bias network is bootstrapped, so you loose little to none voltage swing. The output stage could be mosfet or EF2, etc. Change the resistors from the bias network to fit your need.
Reactions: lineup
1. If the (not an opamp) parts of the circuit contribute any voltage gain, the frequency compensation scheme needs to take this into account.
2. If the (not an opamp) parts of the circuit contribute any significant phase shift (say, > 10 degrees) in the neighborhood of the gain crossover frequency, then the frequency compensation scheme needs to take this into account.
There's a reason why opamp-current-booster ICs like the LT1010 and the BUF634A and the HA5002 (my favorite), provide zoomed-in and detailed graphs of phase shift vs frequency, between 100 kHz and 30 MHz. The manufacturers are keenly aware that composite amplifier stability depends on both the upstream opamp and also the downstream current booster.
Reactions: jxdking
Have you tested the GainMargin and Phase Margin?
You may need a capacitor from opamp output to the inverted input.
As long as keep the unit loop gain bandwidth below 1MHz, it should be fine. Take OPA2134 for example, from its manual, it has “Gain bandwidth product” 8MHz. If the close loop gain is 20 times. Thus, the unit loop gain bandwidth is only 400KHz. I don’t need small cap on the feedback resistor.
Most output devices can do 1MHz. It might be a stretch for some really slow devices such as 2n3055. Lower the bandwidth accordingly if you choose slow devices.
Reactions: Drbulj
Check with at least 20kHz sine wave signal rail-to-rail to see if the circuit is able to provide enough current to the mosfet gate input, since the input capacitance is considerable (Ciss=1700pF).
For source follower, the input capacitance is essentially bootstrapped by the output. That should not be an concern. Will do 100K square wave to demonstrate that.
Reactions: ron68
