using 'steel wool' as box stuffing
For me, It's mainly the Cotton Wool : harmless, easy to work, consisitent, affordable (insulation material - I think I paid 50 Euros for the package below in a local DIY supermarket) and offering fine, efficient damping results :
T
Reactions: indianajo and GM
Thanks for the input @Galu ! Interesting comparison 😎 😎 😎
Sometimes yes, I use Coarse or Fine Wool mixed with Cotton Wool, notably for Midrange speaker cavities (as shown in my last post, lower right pic. Since these do not have the same density, I figure that, for the mid to treble range, it's a probably a more efficient, "spreaded" solution. For Bass, I stay with Cotton Wool, which is more consistent (panels) and densier than Coarse / Fine Wool.
T
  • Thank You
Reactions: Ixnay, GM and Galu
Has anybody tried the felt pad type material used in cars (under the carpet) in speakers?
Those seem to be synthetic fibers stuck or heated together.
And of course polyurethane foam, again used in firewalls in cars, among other things. There is a type of mattress slab with a flat side and a side with tapered blind hole, that might be useful, or has been tried earlier.
In a damp tropical climate, I would prefer a synthetic material, less chance of damp induced rotting, or fungal / mould growth.
Steel wool as a speaker stuffing material....what were you smoking or mainlining, dude?
It may be a combination of this and that, but I wouldn't know where and when. Experimentation, yup, just like Edison, will get you there sometime before you dye. Hint denim material is better than Tie dyed T shirt material. Has anyone tried stuffing a teddy bear into a cabinet?
But as crazy as it gets, stick to some of the more common solutions. I like the idea of a material that can be teased out to different degrees according to its position in the cabinet.
Well, bless your cotton socks, Cal!
And bless your scotch soaked ones Galu. I welcome your invitation my friend. I am near retirement.
I have been called things worse than a sock sucker but I’m pretty sure you don’t want to see pictures of that guy. They wouldn’t even let me in the hospital to apologize. I was hurt.
I had once moved a speaker near my old CRT screen TV, and the magnetic field made the colors go funny, had to degauss it.
Similar effect might occur if you use a magnetic material as stuffing inside a speaker, distorted magnetic fields meaning coil and cone not getting same force all around the periphery of the motor.
The chance of getting stray bits in the gap is pretty high, meaning rebuilding the speaker, a pain in wrong place.
Even copper wool is magnetic to some extent, and now the price is quite high. As a magnetic and radiation shield in medical equipment, yes, but in a speaker, not recommended.
With a heat conductivity 7.5 times that of copper, my money is still on carbon nanofibres.
Only £216 per kilogram - inexpensive in audiophile terms!
It may be sufficient to introduce a small quantity of carbon nanofibre material into wool or cotton.
  • Thank You
Reactions: GM
In the context of this thread, any absorbent material that is a better conductor of heat than air is a candidate.
It is not so much about heat conduction as it is about Specific Heat and fiber surface area per pound. lower density materials fill more space and have greater surface area. A pound of fine fluffy fiber stuffing will adsorb and return many more BTU's than a pound of steel shavings or copper chips at the speaker's resonate frequency.
At a given frequency there is only so much time for the stuffing to adsorb and return heat. The finer the fiber the faster and greater the number of BTU's transferred in the time determined by the frequency.
Thanks DT
Only a piece of information at a time. People will only read only a limited number of words at a time.
Reactions: GM
