If you like it, does it matter how it measures
Yes, these are entertainment systems. If yours keeps you satisfactorily entertained, in the way that you define that, it is well doing its job. Should some perfect measuring system entertain you, then it is doing its job equally well. Neither listener can declare to the other that they are not being entertained, for this or that reason.
Reactions: HeyBill
Some 'audiophiles' believe when comparing something near universally considered to be excellent to something else
that just because they can hear a difference it must somehow be better > how silly is that 😉
PS.
EG. Do you like hearing your impedance curve or your unrestricted frequency response ?
If you like it, does it matter how it measures?​
I guess it's better not to measure. Because when you do, not only the equipment performance, but also your preference or bias would have become exposed, and the results may not be always pleasing.
To answer the question, yes, sometimes it does matter.
Good point, can be biased many ways.
I wont say most people, lets say some people.
Dont know what to think, or even need to care.
But when someone else tells them what is better.
Then they repeat that, as some sort of law or standard.
When actual experience is different or non existent.
Comically, diversity among even music choice or genre vary as well
Heard plenty of demos with junk annoying basic music.
Tell me how great it is.
Sounds like junk to me.
No. If it sounds good, it is good.
Provided of course this opinion is from a DBLT. eg
Many (all?) Golden Pinnae amps are unstable with certain loads, have loadsa xover and other THD bla bla at times ... all dependent on the signal & thermal history. No wonder they sound 'different'.
These amps do badly in DBLTs against boring low distortion amps which don't have such 'features'.
The only exception I've found in some 2 decades of DBLTs is the original JLH Class A 10 W. Operated within it's limits (only 10W into easy loads) this 0.1% performance was preferred over boring low distortion amps. Otherwise, 'boring' amps are preferred in DBLTs.
I've spent a lot of time, without success, attempting an amp with it's distortion profile without the added space heater.
