hello everyone, I need a design for a nice powerful double 15 sub, I was thinking of a manifold or band pass hybrid type b2 design but with 15" but I can't find anything, can you help me?
I listened to the 18 nanifold eighteen sound project and a copy of b2 With 18nbx100 and they sounded like I like, I just need them to go down a few db less 🙂
currently I used the woofers on a bandpass design similar to fbt subline / maxx10sa and on tham 15. the bandpass design seemed stronger to me at outdoor parties using 15hp1060 3 15nbx100 cut at 100hz, but I would like something more!
there are these on youtube but will they work?
thanks
thanks
You can send me a pm if you want, I might have something that is interesting for you.
PS: don't look to much at those YT accounts, most of it is BS and not made with anuy knowledge about the subject.
"I just need them to go down a few db less"
I think you meant hertz instead of dB's.
10ft TH.
Throat = 6" high x 18.25" wide.
Mouth = 13" high x 18.25" wide.
10ft TH.
So the drivers are in top of each otherSimple single fold due to the 2 driver diameters.
As per dimension you can't side to side .
That will look like a PAL12 on steroids !!😎
See post #27,28 and 55Dual 15, 18 Is big
Dual 15 TH with the drivers side to side , so the box looks more cubed than a skinny rectangle.
Art,
i found one one of your creations ,this doodle dated 1/17/08
Cab is 45x30x43.5
it is for dual peavey low riders?
you named it B LOW RIDER
so it can hit the Low B on 5 string bass ?
31Hz
Cab is 45x30x43.5
31Hz
- maxolini
- Forum: Subwoofers
Correct, inline.
PAL12 = double fold.
My model is a single fold.
- Subwoofers
- plans for manifold 2x15 or D&B B2 style
