Does anyone use the Comtrue CT7601?
Has someone measured it?
What kind of measurements you mean?
I have I2S out -> I2S in (loopback) measurements:
@savan I am researching this adau1463 circuit. it has a usb transpoter using ct7601sr with both input and output, I want to play around a bit to redraw it later and try the firmware version above, it only has output mode 🤣
I have the same board, I modified one of the example projects in SigmaDSP and routed the CT6701 USB input -> I2S Out (CT7601) -> ADAU1463 -> I2S In (CT7601).
In Windows Control Panel I looped through the onboard sound card and I can hear through the notebook speakers what I send to the CT7601.
I can use the CT7601 as both input and output.
